Issues to look for
Issues to look for
In about six weeks I'm going to be looking pretty hard at getting a '10 or '11 XKR. I know about the timing tensioner potential issue and what to listen for to find it, but are there any other specific issues I need to watch out for? Also, is there anything in particular I should look for, other than the usual items when buying any used vehicle?
Thanks in advance.
Thanks in advance.
winstonsalemncxk (10-04-2017)
The timing/tensioner problems were with the 4.0L X100 models up to the end of 2002. I don't believe there has been a noteworthy problem with the 5.0L engines in this regard. The 4.0L engines had plastic secondary tensioner/guides that were prone to cracking and then breaking usually ending up in catastrophic engine failure. Replacements were metal tensioners.
You're new here. Fortunately there have been hundreds of other who have done the same thing as you are. I'd recommend reading back the past 40 pages of threads and learning about what goes bump in the night on these cars. It'll give you a much more confident position in buying the car. Subscribe to the threads that interest you (the duckbill and lug nuts ones are mandatory) and once you have your new ride go over it.
Add the battery threads to these.
Other common problems are dash leather shrinkage and convertible rear window separation.
A lot of what to look for depends on who you are and what you know. And what time you have for cars, and how particular you are that everything be "right".
But without knowing that:
buy a car with records kept
in good cosmetic condition in and out
keep an eye on coolant and oil levels when you first get it
and enjoy!
and enjoy!
As mentioned, the tensioners were only applicable to the early 4.0 litre engines. The years that you mention had a few water pump leaking issues but other than a pile of electronics and electrics trying to use up the battery, they are pretty much bullet proof. You might check that the rear window, if a convertible, is still completely glued in. Be aware that age degrades the soft suspension components like bushings almost as much as driving.
and enjoy!
and enjoy!
Are there commonly issues with coolant leaks in the 5.0L?
At 7 years old, I expect to replace a few bushings. I be the sway bars will need new ones.
The reason you don't really find much issues, is well...there aren't.
I've noticed from browsing car faxes that 2010 MY OEM water pumps tend to make it to about 45K miles. The design got superseded several times.
Other than that, I've mostly just seen "computer issues", tires, brakes, coolant hoses.
So long as you buy a car in good condition: it should just run and keep running with only regular maintenance.
I'd get the codes read. The adaptive headlamps in the 10/11 years are prone to throwing errors which is really annoying when it flashes on the dash and a permanent fix can be expensive. I'm not sure if that persisted into the model where they have the changed headlight shape, with LEDs. If it is throwing the errors for the adaptive headlamps I'd try to get the modules replaced.
The TPMS can play up as well but the fix for that seems to be to overinflate and run it for a day or two then let the tyres back down again.
Other than that mine had a creaky steering rack which was fixed during a service, and was otherwise trouble free when I had it between 40,000 to 60000kms.
I see you mentioned the seat comfort above. It actually took me ages to get the seat right, there are so many options it was something I was fiddling with for weeks. So unless you are very lucky or very clever, dont be surprised if you cant crack it on the first drive. Once you get it right though the seats are sublime.
The big issue with the battery/electronics can be solved quite simply for less than $100. Purchase and use a battery maintainer when your car is not in use, particularly if it is not to be a daily driver. The maintainer of choice on the Forum is the CTek.
You can find several threads about battery maintenance and Ctek's; just type Ctek in the search box in the upper right corner of this page. Incidentally, Jaguar has a private labeled Ctek in its accessories catalog.
