I've owned a Jaguar for three days and it's already in the shop!
Old 02-14-2014, 04:16 PM
Lothar52's Avatar
Hahaha!! Wring it good!!
Old 02-14-2014, 04:24 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Originally Posted by carlprs
what is an auxiliary motor??
Maybe he means the auxiliary cooling pump (for the intercooler on SC cars).
Old 02-14-2014, 10:09 PM
sharx8's Avatar
Originally Posted by sov211
And if this XK is not going to be used FREQUENTLY, do yourself a favour: get a CTEK battery maintainer, install it permanently and use it when the car is in the garage. That will eliminate any battery worries and the random and perplexing electronic glitches that low voltage causes in these cars. Virtually every electronic gremlin is caused by the battery! These can range from odd warning lights, to window, seat, hood operation being erratic or non-existent, SatNav problems, etc - all caused by a battery not kept at full charge. (this is not an opinion, it is an experience-based statement).
Agreed wholeheartedly. Something every XK owner should do... And so easy.
Old 03-21-2014, 07:28 PM
BillyD's Avatar
Originally Posted by Ngarara
You may need to do a hard reset on the infotainment & sat radio systems - pull fuses 21 (15A blue) and 25 (10A, red) in the rear fuse box behind the vertical panel between the back seats, leave them out for a minute or so, then bung them back in. No guarantee this will work, but it's worth a try.
Is the ignition ON or OFF to try your advice?
Old 03-21-2014, 07:40 PM
Ngarara's Avatar
It may be better to do it with the ignition off, just to avoid a bunch of error messages popping up on the dash.
Basically, even when the ignition is off, the various modules are still powered up. They draw a tiny current, just enough to maintain the 'volatile' working memory that contains various learned settings. The main firmware & factory settings ('maps') are stored in flash memory that isn't affected by power loss, but when you pull the fuse, all the volatile memory is erased, and the module reboots when you bung the fuse back in.
BillyD (03-22-2014)
xjrjag
10-27-2021 11:48 PM
reedmtn
01-15-2016 07:24 PM
MarathonJohn
09-03-2015 07:59 PM
daro31
09-01-2015 10:24 AM
gene1
08-27-2015 08:56 PM
Quick Reply: I've owned a Jaguar for three days and it's already in the shop!
