Jacking point pad for trolley jack?
Hi, does anyone know of a correct shaped jacking pad to fit the XK nicely, ones with a V in them very common, (weld seam pads) but would like to put the weight behind the seam between the two nuts on the back jacking point as in front of the seam bit it plastic side skirt, could make nice fitting one out of hardwood i suppose, but just wondered wot you guys used or is there an off the shelf pad? Thanks in adavance
scjordan1969 (11-25-2021)
Received 1,975 Likes
