Is this a Jaguar windshield issue
In the northeast we have this toll pay system called EZPASS. We get a small transmitter to put on our windshield which is triggered when we go through a bridge or toll road. I took the one from my wife's car and am using it in the XKR. So far it failed to trigger the toll gates twice. My car has the heated front windshield and I was wondering if this would cause the problem. My question is has anyone else had this problem and do you have the heated windscreen . I get no help from the EZPASS people. I have 3 other vehicles and this same transmitter works in these cars.
Hey Jagtoes
Just an idea.
I had the same issue in the UK at Dartford toll bridge I moved the location of the transmitter a few times until I found a workable position.
I thought it may be the angle of the screen at first
Many cars have heated front screens and its does not seem like an associated problem.
I would suggest you leave the transmitter loose next time you go through the toll and see if by moving it around activates it.
BOL Halex
Just an idea.
BOL Halex
Lothar52 (06-08-2014)
Hey Jagtoes
Just an idea.
BOL Halex
Just an idea.
BOL Halex
Yep have seen that and as I had a difficult decision in mounting a front licence plate this would be tougher (uglier) LOL
While I don't use an EZPASS in New Mexico because we don't have toll roads, I have a close friend in Florida who uses an EZPASS device.
He has small suction cups attached to the device and just sticks it close to the mirror when leaving home knowing that he will drive the car on a toll road.
When not on a toll road, he keeps it in his glove box in a foil type bag.
https://www.ezpassnj.com/en/about/exterior_tags.shtml
jagtoes (06-08-2014)
I just hold my ezpass to the glass as I go under the system (I just use it for a toll bridge).... But in truth it only triggers half the time. Still not a problem because when they run my plates, they see I have a pass (and the image shows it on the glass) so they adjust the price manually...
My point is even without heated glass it can be flaky....
The heated screen will have very fine METAL elements running through it. These will make the screen largely opaque to radio frequency (RF) energy. I believe the EZPass device in your car is very much like an RFID tag that you see attached to merchandise in a store. The toll area has transmitters/readers that detect your EZPass... or not if your car has become a Faraday cage.
It does (there is usually a paragraph in the manual that mentions heated screens). There are also several cars that set of my laser detector when they drive by - Any Infiniti with a heated windscreen will set it off and it reacts from quite some distance away. The tail lights on the Trailblazer do the same thing.
X_Type_South_Africa
12-09-2015 05:37 PM
FS[MidWest]: 08 XKR Convertible 59,XXX miles
MrNobody
08-27-2015 07:49 PM
