JAGUAR XK 4.2L 8-cyl Self Service Parts List
I was not able to locate this information easily so I thought I would share. I own a 2009 XK without warranty and do my own maintenance. Useful info for the rest in my camp:
LUBRICANTS & FLUIDS
Engine Oil
Full Synthetic Castrol 5W-30 is factory recommended for all climates. Other suitable options depending on climate: 0W-30, 0W-40, 5W-40
Automatic Transmission, 6HP26
Shell M1375.4 - DEXRONŽ-III Automatic Transmission Fluid
Differential, Rear......GL-5
All TEMPS......75W-140
80W-140 Synthetic Long Life Gear Lube
Fluids
Power Steering Fluid - DEXRONŽ-III Automatic Transmission Fluid (not a typo)
Brake Fluid - OEM recommends Shell ESL Super DOT 4
FILTERS:
Oil Filter MANN Oil Filter (W71329) - Recommended
Oil Filter WIX 57302 Oil Filter
Cabin Air Filter BECK/ARNLEY 042-2131 fits 03-09 Jaguar XKR 4.2L-V8 or Mahle LAK364
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine Oil, with filter..........7.0 quarts
Cooling System, Initial Fill..........10 quarts
Automatic Transmission, Total Fill
6 speed 6HP26..........10 quarts
Differential, Rear..........2.7 pints
TORQUES:
Oil Drain Plug.....18 ft/lbs
SPARK PLUG
Part No. C2A1535
Supersedes AJ84575 LR005253
19 mm reach; 14 mm thread
Gap 0.9 - 1.0 mm
WIPER BLADES
Denso Windshield Wiper Blade 160-3121
LUBRICANTS & FLUIDS
Engine Oil
Fluids
FILTERS:
0 Fittings, 0 Plugs
CAPACITIES:
TORQUES:
SPARK PLUG
Part No. C2A1535
Gap 0.9 - 1.0 mm
WIPER BLADES
The following 9 users liked this post by Zandolini:
coordpoint (01-25-2016),
guy (08-02-2014),
LstFord (07-31-2014),
MCX (12-01-2023),
Mike V (07-31-2014),
and 4 others liked this post.
Not yet, but let me know if you find one.
It is the first time I have seen this as well and I had to triple check. The official X150 Workshop manual calls for Dextron III for the power steering, strange but true. And yes, oddly convenient!
Zandolini,
If you compare a Wix 57302 filter with the OEM Jaguar C2C41611 you will find that the WIX is smaller in dia. and the gasket is 50% narrower.
So......I am switching to OEM for next XK oil change for above reasons.
I am a little disappointed because I've used WIX for many years for all my cars,motor home and boat(twin Chevy's).
And Jag. filters not that expensive >$20.........
I also use Mobile I 5W-30 in the 2007 XK.
Cheers,
Cheers,
Zandolini (08-02-2014)
I'm often mistaken, but, the OEM cabin filter may be a Jaguar branded Mahle LAK 364. OEM spark plugs, at least for the early years, are NGK (don't have the number but it's available on the forum). The ones I bought from a dealer have Jaguar inventory label on a white box, but the actual plug a painted NGK #. The wiper blades are made by Denso and can usually be found on the internet for circa $17 each plus shipping. I think the Jag list price is $23. When a service adviser told me the blades need replacing I asked how much: $88 - that was four years ago.
Vector
US Lower Atlantic
08-26-2015 05:36 AM
