Jaguar XK Loose seatbelts
Hey guys,
I bought a 2010 XK recently and have noticed an issue with the seatbelts. I was wondering if anyone else has noticed the same thing (and if this is normal or not).
When I am driving, if I pull the seatbelt chest harness out, it retracts very slowly. Sometimes, it does not retract at all leaving a stretched out seatbelt in my lap. If I push the button in on the seatbelt as if I were taking it off, the shoulder harness retracts quickly and resumes tension. It seems to me that the seatbelt should always have tension on it. As it stands right now, this seems to be a big safety issue since if the belt is not retracted when driving, it will not effectively restrain me in an accident.
Can someone else check this out in your XK to see if this is normal or not? Not sure if there is an adjustment the dealer can do or not.
Thanks,
Chris
Thanks,
Chris
Not sure with your year XK, but Jag has what they call ARTS (Advanced Restraint Technology System). This is obviously an electronic controlled seat-belt pretensioner system that may allow for a comfortable fit yet instantly tighten in an accident.
Others with your car can give you something better than my guess....
BOL
Vince
BOL
Vince
Hey guys,
Thanks,
Chris
Thanks,
Chris
The spring mechanism which puts tension on your belt may be worn, or may need adjustment.
Thanks, rscultho.
I took my car to the dealer to get inspected today and I had the manager take a look at my seatbelt. After foolling around with it a bit, he agreed to order me a new seatbelt under warranty! The part will be here next week. I will keep you posted if this fixes the issue.
The tension on the belt I experience if I pull it out and let it retract while driving is much less than what I feel when I undo the seatbelt or use it with the engine turned off. In fact, when I pull it forward while driving, sometimes I cannot get it to feed back into the shoulder casing at all. I am forced to take off the seatbelt to retract the strap and put the seatbelt on again to experience a comfortable fit.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
