Jaguar XKR 2010 mirror body part number?
Hello!
I have a problem with my Right mirror (passenger mirror, as I live in Europe, not UK).
It does not fold any more.
Questions:
1. Can someone help me with a part number?
2. Is this part used on other Jaguar models too?
Red Jaguar XKR 2010
XK / X150
Thank you
Questions:
Red Jaguar XKR 2010
XK / X150
Thank you
You need a RH mirror. In Powerfold Door Mirrors, there's electrochromatic and non-electrochromatic options. Further to that, Part Number changes with VIN range. I recall previously checking a question about compatability with other Jaguar model mirrors and finding the P/N's are different.
Before jumping into the considerable cost of a new mirror, I recommend some investigation to determine whether the fault is electrical (circuit / switch / motor) or mechanical (drive gear). You could, like several others before you, buy a new mirror only to find it doesn't fix the problem.
Sean W (07-26-2023)
I'm following this thread because my tired XKR has fully working power fold mirrors, and it's the first Jag I've owned where they haven't given up the ghost long since. I'm interested to learn what proactive maintenance is possible to keep them limber. In my last car - an XJ - they'd failed because the gears were a corroded mess and the motors couldn't get them to move (and nor could I) and as I recall their shaft connection was slipping. I suppose a slipping interference fit shaft could be temperature related - but I'm not (yet) familiar with the XK mirror design.
bgpenguin21 (07-28-2023)
I assume that includes pivoting forwards against the body i.e if hit from the rear of the car. So, can I push the mirror housing in that direction without harming it - hoping to find some lubrication access?
No one else drives my XK and I could just leave the mirrors in the same set position. I did this on my 2007 XK and they had definitely become "lazy" when I did eventually move them after three or four years. They'd lost the smooth action. I have my 2014 set to fold when I lock the vehicle and I also move the mirror glasses whenever I wash the vehicle. Nine years old and they still operate very smoothly.
The following 2 users liked this post by GGG:
bgpenguin21 (07-28-2023),
justinhill (07-27-2023)
Fair point... although I was imagining doing this no more than once a year to get some grease or something into the mechanism.
McJag222 (07-28-2023)
