Jaguar XKR-S Arden
Hi David,
I am puzzled by your description of your car. Your Public Profile says it's a 2009 XKR-S Portfolio Arden, and that you're in Puerto Rico.
The 4.2L Jaguar XKR-S was a European-market only, limited-edition made for the final year of the 4.2L production and was not sold in the USA. The 4.2L XKR-S was marketed as a 2008 model because the 5.0L European models began in 2009 (2010 in North America). The 4.2L XKR Portfolio was a North American limited-edition model that was available in 2008 and 2009.
Arden is an aftermarket German tuner.
https://www.arden.de/en/refinement/
Can you post some pictures of your car, in particular a wheel and a door sill plate? The 4.2L XKR-S came from the factory with Vortex wheels and the 2009 XKR Portfolio came from the factory with Selena wheels. Your car might have Arden wheels and other Arden mods. How long have you owned your XKR-S and what is the VIN? That'll tell us exactly what you have.
Can you explain what the problem is that you're having with the Bluetooth? Is it not pairing with your phone? Are you trying to stream music using Bluetooth? I'm not sure if the Bluetooth module you referenced (6W83-10D893-AE) is correct for your car.
See this thread: https://www.jaguarforums.com/forum/x...riment-152498/
Hope this helps.
Stuart
Hope this helps.
Stuart
Hi is my first time here in the site, so i'm try to send the picts.
The problem with the Bluetooth is, i can't connect because on the screen at the lower side appear the image of the Phone with a slash on it, and when i hit the phone function on the screen appear a sub menu a i can't select anything, the system ask to pair a phone but when i hit YES nothing happen.
thanks
Mr. Rodri
thanks
Mr. Rodri
I found this 4.2L XKR Arden video, but it doesn't say much. The original tail lights were replaced with the 5.0L LED version, and the wheels, exhaust and diffuser are aftermarket Arden. The reason it's definitely a 4.2L XKR is the front bumper fog light design. It appears that the claimed 480HP is from ECU and exhaust mods.
David1013 (04-23-2020)
Hi Marky, I bought the car like two years ago and the car has the problem allready, I check all the electrical system and work perfect, some guy tell what i need the module, I check on ebay but all the ones are used and I'm afraid, Isend the pic to youcan see the screen and see if you can helpme.
It’s a Naca duct but to what I don’t know. Perhaps it’s decorative. Otherwise I actually like the body kit (bumper covers & side skirts).
David1013 (04-26-2020)
https://www.favcars.com/pictures-ard...2007-09-345223
https://www.supercars.net/blog/2007-arden-xkr-aj20/
https://www.motor1.com/news/36699/ar...-jaguar-xkr-s/
So a unicorn has been found back to David's original query, for his car it would be fair to say that Arden didn't mess with the BT module, so is the module he needs a US or European one (am guessing they may be different for frequency reasons)?
I do wonder how it got across to Puerto Rico
