Jump Starter box with long cables
I'm looking for a jumper box with cables long enough to hook up to my 2010 XKR. I have a small jumper box in my daily driver but it only has about 6" cables which are sufficient if your car has jumper connection points under the hood but are insufficient for the Jaguar method.
I know I can buy a larger unit like the road service guys use, but I was hoping to find something more convenient. Any ideas?
Received 2,626 Likes
Someone please correct me if I am mistaken.
I would not use jumper cables in the XK.
1. you don't really have space to carry long enough cables.
2. you can potentially damage electronic or charging system.
I would carry a portable power supply as the one in the link below, it can fit in your glove box- if you chose to keep it there.
Do I have this wrong?
https://www.amazon.com/dp/B06W2LRQNR..._t1_B01LSISK90
The following 4 users liked this post by jagtoes:
Yes, thank you for clarifying. The issue is the small jump boxes such as the one Q&C listed is similar to the one I have in my daily driver. The issue is when the positive is hooked up the box is right up against the left side of the car and I only have about 6" which is insufficient to find a ground. The one Q&C listed apparently has about a 12" cable which I also don't think will reach an appropriate ground. Question for Q&C, does the Amazon product you listed attach appropriately on your XKR?
I don't see a downside. Perhaps someone can chime in what cautions one should take.
I find it easier and faster to remove the 4 thumbscrews that hold the back cover where the battery resides. And hook directly to the negative and positive terminals of the battery- this is what your jumpstarter was designed to do. Many of older concerns such as sparks don't exists with this type of a smart power source.
Queen and Country (11-06-2017)
I know that when charging the battery if you bypass the monitor, it gets the capacity wrong but has never bothered me.
