Jump Starting a 2013 XKR
Actually that is the positive +, you can use one of the threaded post down in the spare tire storage for a negative -
drbbop (07-31-2018)
The positive terminal is the one with the black rubber boot over it......you can see it is insulated from the body. If I'm not mistaken the negative terminal in the spare tire well. It is advisable to not have the donor vehicle running so you are just using its battery for the jump. Once your XK is started disconnect the jumpers right away (neg first).
drbbop (07-31-2018)
The following 2 users liked this post by GGG:
drbbop (07-31-2018),
winstonsalemncxk (08-01-2018)
Received 1,975 Likes
drbbop (07-31-2018)
kbernal1016
09-15-2012 02:15 AM
xjr4life
04-16-2010 06:57 AM
harounq21
06-19-2008 06:12 PM
