Just throwing it out there...
That looks pretty slick. Not the cheapest thing in the world. You can get a full scissor lift for just a few hundred dollars more. And that will get you almost 5 feet in the air. But the scissor lift is barely portable. They probably weigh 500lbs or more.
I could really use this when I change my transmission fluid. Anyone in Charlotte, NC want to go 50/50 on one?
Govtslug
Govtslug
Received 1,975 Likes
I'm not sure it's specified 3" collapsed height is low enough to slide under my car.
My hydraulic floor jack doesn't fit at the lift point behind the front wheels, I need to use the Jag jack from the trunk to lift the car just a bit, so I can get floor jack under, and then lift the car (coming down is easier, as the suspension doesn't fully compress immediately, so I can pull the jack out).
2 ton Low Profile/Long Reach Steel Heavy Duty Floor Jack with Rapid Pump®
Floor height of the saddle is approximately 4".
Referencing your using the Jag jack, Horrible Freight had a sale on extended reach, low profile jacks, They are very low and the extended reach is very helpful. I've had it for a couple of years now.
Marka
22
09-11-2016 12:09 AM
Paulie710
09-28-2015 03:49 PM
