Kasuga rims - tire sizes
Hi everyone,
I've been looking around for some 20" rims for my xk and I've pretty much settled on going for Kasuga's. Now I've got a lead on a really great set which the seller claims will fit on the xk and xj, but the tires fitted are listed as being 245/40/20 and 275/35/20. This seems correct for the xj but everywhere else I've looked seems to suggest that for the xk 255/35/20 And 285/30/20's should be fitted. Any thoughts?
TIA,
Tony
TIA,
Tony
Hi everyone,
TIA,
Tony
TIA,
Tony
Hi everyone,
TIA,
Tony
TIA,
Tony
The 255x35 = 89.25mm
The 275x35 = 96.25mm
The 285x30 = 85.5 mm
So, the 255 and 285 combination results in nearly 18-20 mm difference in the tire/wheel diameter which means that with this set the car would ride about 9-10 mm lower. It is also likely the size that your speedometer is calibrated for.
Albert
lickahotskillet
10-18-2015 09:51 AM
Gerard Radimaker
09-13-2015 10:33 AM
lickahotskillet
09-11-2015 07:54 PM
