Keyless entry?
I would like to have keyless entry on my car but I cant innitiate it!
When I'm in the menu for it there are three options for keyless entry but when I push ON on any of them they go back to OFF right away? I had a Foxwell diagnostic tool on the car and it said Keyless entry module is fine.
Charged til today but still the same!:-(
When fully charged it showed 12,76v
Turned the ignition on and tried to initiate the keyless mode, fiddled around for maybe 5-10 minutes and then turned ignition off. Checked the battery voltage and it showed 12,1v.
Should a good battery hold 12,5v right after ignition off or do they drop a little? Cause after ignition off it takes a good while before all modules and light go off.
A member on another forum asked if I had the small black rubbers on the doorhandle and I don't. He said early cars did't have that option.
Why I have the keyless entry mode in the menu could maybe have been done by the workshop( not a jaguar dealer) that updated the software. The previous owner told me it had been updated last year but he didn't know what.
Now I know why it doesn't work and I have one concern less!:-D
Thanks for the tip on double locking so the computer/modules go to sleep earlier.:-)
Received 1,975 Likes
If you can discern the VIN then you can go to Topix and insert the VIN where called for and get copy of the build sheet for your vehicle. That may tell you whether you have remote entry or not. The build date is on a label on the left door jamb along with the color and trim codes. If it hasn't been removed it should be easy to find.
Probably only for US cars so tried an European site and it found my car but it didn't show the spec on the car.
