Last chance to replace water pump
#41
Sean W.........It's not even questionable. I am crazy!.....I'm over the top OCD and am nuts about my cars. Yes, the car always had a problem. Don't make me worse than I am! I'm aware that they have to do it right and that it hopefully will hold up......The rest is out of my control. I do have a well known Master Tech working on my car and supposedly he knows me over the years. I stop by the dealership regularly and chat with the techs and staff. . There's an Easy Care rep coming by tomorrow to give the green light. I was told they periodically come out to dealerships for sporadic checks. It's really a small job for them....I'll check in after completion.....Did you expect me to do anything different?? lol
#42
#43
#44
Queen and Country (03-06-2020)
#47
FINALLY! After years of attempting to get my original water pump replaced under factory warranty (4 attempts) as well as with my Easy Care extended warranty, it is finally done! My 2010 XK presently only has 11,500 miles on it. It had to get approved by the warranty company...They sent someone down to take pictures and approved it. I picked up the car on Saturday and have driven it constantly with one thing quite noticeably different.....NO COOLANT SMELL. I'm familiar with the master tech and he understands how particular I am. I told him I wanted it thoroughly hosed down to remove any coolant residue and that i expect every single clip, clamp, and miscellaneous piece replaced exactly as it should be. Well all checked out fine and I am finally a happy camper. Persistence pays off....sometimes.
The following 5 users liked this post by bocatrip:
kj07xk (03-09-2020),
pk4144 (03-11-2020),
Queen and Country (03-10-2020),
ralphwg (03-10-2020),
SinF (03-10-2020)
#49
Stuart.....You are so right! I was close to accepting I can't win and would be resigned to living with it. I did know with certainty that there was a leak, but not being a tech, i could not say with certainty it was the pump, especially with all the plastic.. All is well that ends well. Now I can finally enjoy my car.
Cee Jay (03-09-2020)
#52
#53
Mine was changed just over 2 years ago. Haven't lost any coolant yet but still have a slight smell once in a while when I pull into the garage. I assume it's just burnt left over coolant from the previous leak in the engine valley.
#54
Did you hear suspicious tick-tick-tick at the startup? It could be early signs of timing chain tensioner on the way out.
(I am probably going to hell for this)
The following 2 users liked this post by SinF:
guy (03-10-2020),
#55
Are you certain you had the most updated water pump installed? The part number should be AJ818909. If the residue coolant is not thoroughly rinsed off, it can linger. How many miles on your car? When was the pump replaced? It's also always a possibility that the plastic parts can have small leaks. Are you losing coolant?
#56
Water pump and gasket
Hello!
I donīt want to hijack this thread, and I havenīt had any issue with my 2007 XK 4.2 Convertible , but, from what Iīve heard, Jaguar water pumps are always suspect.
There are better pumps out there: WHICH ONES? PLEASE tell me your experiences!
I have one on order ( just for insurance ;-) ), that has an Aluminium impeller. Costs half of the original ( 129, IIRC ) , and the seller ( reputable Jag parts dealer ) says, its very recommendable. I donīt care for cheap, I want simply the best.
Next problem: the original, good, reliable metal ( Aluminium ) gasket is out of production. Only single specimens left on the market. It was reportedly 4 mm thick, which seems excessive. 0,4 mm? 1,5 mm? Iīve heard both measurements. The new ones are cheap, thin, paper, and need additional caulk.
Please: what are your experiences, Gents?
TIA, Hermann
TIA, Hermann
#57
Hello!
TIA, Hermann
TIA, Hermann
#58
I don't check the level very often (once or twice a year) but I usually have to top up around a centimeter.
