The Last Straw?
Queen And Country,
I have driven the car regularly. Actually the exact amount that I drove my 2010 Audi A5 previously.
I am honestly not familiar with what amount of driving is necessary to maintain a charge. As I have said the car has gone 2 weeks without being driven and started. It has also failed to start 2 days after driving an extended trip (more than 30 minutes).
I do not know, since it wasn't written in any manual, what the exact amount of driving should be in order to re-charge the battery.
I recognize these cars require an extensive amount of battery strength to maintain their functionality. At the same time I believe it is Jaguar's responsibility to create a vehicle that can maintain its battery power during "normal" driving conditions.
I believe my driving of this car has given the battery ample time to regenerate.
Not sure why you suggest that it is not Jaguar or Battery Drainage and must be "user" error?
I hear you, you bought a car and you want it to work without any additional fuss.
Think of it as a limitation of an emerging design. Its absolutely not user error. Or manufacturing error.
There isnt another battery or alternator in the world that would solve this problem. I do blame Jaguar for not building in a charger.
Do this and your problems will absolutely be over. (its little effort on your part)
1. Make sure you get a fresh battery. (the ones at Pep Boys come with a 4 year free replacement)
2. Charge it once every 3 weeks. Using the charger everyone is talking about. It can be attached permanently in the trunk by any mechanic. If you chose to do this at a dealer just buy the Jaguar charger and negotiate that they install it free for you, due to the trouble you have had.
It took me a long time to find the scientific reason that this is happening. Every battery has a set number of cycles- You can see this in store bought batteries that say you can charge them 500 times. In the case of this battery (AGM) the number decreases dramatically if you deplete it between full charges. So, if you only deplete it 50% between full charges it can go 1500 cycles- thats good for 7 years. If you deplete it 90% then charge it, not only will you only get 300 cycles, the capacity goes down with each discharge- i.e. percentage wise you will deplete it even more as its capacity gets lower.
It costs around $70 to buy a Ctek charger and a Ctek comfort cord. It takes no more than 15 minutes to install the comfort cord in your XK. then you plug in the battery tender/charger just like a lamp or any low wattage appliance.
After installation it takes maybe 10-20 seconds to hook up or unplug the Ctek. That's what I did and do, and I have NEVER had an issue. Sometimes one has to make an allowance to get what one wants. So, if you want to drive an XK or an XKR (2010-2015 MY) make that allowance, it is a small price to pay for great enjoyment.
Easy connection to the battery inside the trunk and easy to connect without even opening the trunk lid. Takes 5-10 seconds to connect as mentioned. CTEK is a fast connect plug.
The images below is the set up on my 2009 XKR Portfolio Edition.
Click image once to enlarge, click again for full screen.
Jahummer,
I understand why Jaguar XK owners use a battery tender. My difficulty adapting to that daily procedure is a fundamental belief that the manufacturer should identify the problems and correct them.
In essence all of the Jaguar loyalists (I am not among them as yet) feel that it is worth giving up something for the privilege of owning such an exceptional vehicle. I for one can't understand why "All" of these cars must drain the battery. Shouldn't Jaguar fit the vehicle with an appropriate battery to handle its needs?
As Jagtoes said they "should" be able to detect the drainage problem but going on five weeks now of investigating they are still unable to fix the issue.
My question is since the car is under its original "warranty" what does that word actually mean to the consumer if they can't repair their own car?
My Rules of the Road
Life is fragile, and the road of life is filled with ups, downs, curves, potholes, and other unforeseen dangers. We're here for only a short time, so make the most of every day; you never know when it will be your last. Here are my personal "Rules of the Road":
Rule 1. "Don't sweat the small stuff" - the key to a long and happy life.
Rule 2. EVERYTHING is the small stuff, EXCEPT your own health.
Rule 3. Repeat Rules 1 & 2. Otherwise, you can't help anyone else.
Rule 4. There are 2 ways to solve every problem; the hard way or the easy way. Only masochists choose the hard way.
Rule 5. KISS - Keep It Simple, Stupid
Rule 6. Don't let your ego get in the way of Rules 1-5.
Applying the above rules to resolve Jay's battery problem: Take it easy and buy a CTEK - the best bang for the buck. It's cheaper than a psychiatrist. Or a cardiologist.
Your life, your choice.
Jay, as you drive the car daily and the nature of the problem you are seeing is so unpredictable, I tend to agree with you that Jaguar should be able to find the problem and fix it if it is not the usual wear of a vehicle that is not driven often or far enough to maintain the battery. Please tell us how many miles you drive each day above 60 mph. A thirty minute daily drive at this speed would be more than sufficient to maintain the battery. If on the other hand, you live in the city and it takes you an hour or more to get to work, the time is good but the speed may never get above 30 mph, which is not sufficient to recharge the battery. Before retirement, I worked in the Texas Medical Center which is 25 miles from home, while the distance is good, I was mostly stuck in traffic and crawling along under 30 mph. We took a trip somewhere almost every weekend, this seemed to maintain the battery very well. I hope your dealer and JNA can find the problem and get it sorted out quickly. As a side note, while the dealer and JNA are trying to be helpful, I would ask them to give me a printout of the service history on the car since day one.
JackJohn, I would be interested to see the response, reading what he has said the 30 minute drive was a one-time "long" drive. If there were 2 weeks of very short drives I don't think a 30 minute drive would replenish the battery, not when you have all the electronics drawing (stereo, computers, climate control, etc) power during that drive. I am thinking a long drive is an hour and a half or more. That is just my opinion, certainly there is no documented number that will state what is needed to replenish a battery as you cannot possibly know from what level the battery started!
#28
Its a red herring.
We already know the answer, if it was a daily driver it would not be sitting idle for a week.
Regardless, its not how much you drive. The problem is tons of power draw at crank and not enough charging due to fuel efficiency- including a 6th gear which all but excludes charging at the right speeds. Most importantly a diminishing battery capacity. This is the part that is tough to get one's arm around
#31
Alarms and immobiliers are a normal fairly heavy battery drain, thats why I keep all of my bikes on battery tenders in the garage. With infrequent use its the only way to ensure the battery stays alive.
To save battery I have put bikes and cars into alarm service mode before now and manually locked them up.
Just an idea but possibly its the car's alarm system discharging the battery on that low drain rate.
With the blowers on these cars it needs a lot of starting power because the starter is turning over a high comp blower as well as the engine.
Talk to me about it when I fitted a Rotrex C15 blower on my Suzuki Hayabusa. It killed 3 new batteries stone dead within 3 days of use.
That was resolved by fitting an Odyssey Xtreme battery with massive cranking power and unlimited charge rate while the bike was running.
So with infrequent use of the bike the new higher output battery sorted the problem.
They list batteries for Jagaur cars.
http://www.odysseybattery.com/battery_search.aspx
The following 2 users liked this post by Busa:
Queen and Country (05-16-2016),
ralphwg (05-16-2016)
#32
Easy to understand the frustration. Most likely you will not turn around this week or next and sell the car.
My suggestion is buy the following. Connect it daily. I have made many posts about the attributes of the CTEK battery maintainers. Use this product until and after the Jaguar dealer and Jaguar USA resolves the problem.
This will be one of the best investments you can make for any vehicle. Your XK is loaded with sensors. My 2009 XKR is reported to have 120 sensors on the car.
Amazon.com CTEK MUS 4.3...8 Step...Smart Charger/Maintainer.
Also, buy the CTEK Comfort Extension.
Here are links to make the purchase.
Amazon.com: CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger: Automotive
Amazon.com: CTEK 56-304-1 Comfort Connect Extension Cable, 8.2 Feet: Automotive
You will be glad you made the purchase.
#33
No worries - your CTEK 3300 will get the job done just fine; be comforted in knowing that the 3300 is what Jaguar sells as their re-branded battery maintainer. Like richzak, I also bought the CTEK MUS4.3 because Amazon ran a special and it was less expensive than the 3300. Sure, the MUS4.3 is a newer model with more features, but do you absolutely need those additional features? Probably not.
bocatrip (05-17-2016)
#34
#35
Excuse me for getting off the topic for a moment...Richzak, I purchased 2 CTEK 3300 chargers 2 years ago, one for my Jaguar and one for my Lexus.They have performed flawlessly. Is the 8 step charger you recommend above that superior to the 3300? I'm not planning on replacing mine but was just curious. Thanks.
The CTEK MUS 4.3 is the 8 step charger/maintainer that I spoke off. It has 4 more steps over the CTEK 3300 and is considered a superior charger.
I would suggest you take a few minutes to view the MUS 4.3 and 8 steps and what exactly the CTEK MUS 4.3 does.
I am sure you could list your CTEK 3300's here for sale and someone would jump right in buy one or both, then make the switch over the CTEK MUS 4.3 for the extra internal steps of he charger. Amazon has the best pricing.
As Stuart S. stated, the CTEK 3300 will do the job, but the MUS 4.3 takes the battery maintenance to another level.
Check this out.
New CTEK MUS 4.3 Offers Next Generation Technology Features - CTEK Battery Chargers
Be sure to watch video for an understanding how the CTEK MUS4.3 works.
You will not be disappointed to move up in quality and features of the MUS 4.3 vs the CTEK 3300.
I own 4 of these CTEK MUS 4.3 and I have never had an electrical related issue on any of my vehicles which are all newer and the sports cars are loaded with sensors.
Any other questions, just ask.
#36
Bocatrip:
Check this out.
CTEK (56-864) MUS 4.3 12 Volt Fully Automatic 8 Step Battery Charger - YouTube
Check this out.
i have not had any problems with my Jag's battery with the 3300 so I am confident in the quality of CTEK.
richzak (05-17-2016)
#37
#38
Richzak....I have both my cars hooked up with the eyelets from the Ctek 3300 with a comfort cord. If I purchase the Ctek 4.3 can I just keep the present set up with the eyelets and older comfort cord and replace the charger? I also read somewhere there is no on off switch on the 4.3. Is that true? Also, if it is a new charger why am I reading reviews going back to 2012?
#39
#40
