Latest water pump part number
#41
#42
Hi
Can you share the part numbers for the new C, Y, and plastic bleeder parts?
Having just completed a coolant pump change in my 2010 XKR, the latest revision I found was AJ813909. After a couple hours research looking for the hard (brittle) tube (B in graphic) and the little Y shaped part number (A in graphic) connecting the pump bypass and the throttle body to the heater return, I realized the design had been changed to a simpler and more reliable configuration. The Y part is no longer available, nor is the hard tube. They are replaced by a new design that has a thick rubber tube coming off the large coolant tube (C in graphic) thermostat to upper manifold. As my car is a daily driver who has put about 60k of the 120k miles on my XKR, I try to minimize unecessary downtime. As I do my almost all of my own mechanical work, I would definitely recommend at a minimum changing those parts (for about $100 US) and save yourself the extra hours of labor that will be needed when they deteriorate from the inside out simply due to age. The new design requires replacement of the large coolant tube and the Y part, but eliminates the brittle plastic tube, and you get a new plastic bleeder connection to plug into the coolant pump, which is another common failure point that will cause you to have to go to the new design.
OLD DESIGN - 5.0 S/C
NEW DESIGN - 5.0 S/C (you can just see the new grey colored "Y" part at the top of the picture.)
QP7 (01-20-2024)
QP7 (01-20-2024)
#45
I bought Land Rover parts as they were cheaper; Several sites will provide cross reference numbers to Jaguar part numbers... The bleeder is included now on the large coolant down tube to the thermostat (P/N: RV-LR049989). The "Y" or arrow A in graphic is Throttle Body Heater hose (P/N: RV-LR045238) and the small outlet on it is now sealed and not used since the bleeder tube now connects to the down tube.
#47
sidescrollin
01-09-2018 11:26 AM
supra-raleigh
XJ40 ( XJ81 )
09-23-2014 10:30 AM
Timothy
05-16-2012 07:14 PM
