Leaky car?
With an earlier car, I would suggest looking at the "seal" where the driver's side window meets the rear "quarter" window to see if there's a gap through which rain might be seeping. As we know, there's been a lot of rain the UK over the past couple of months.
But - not sure if the design of yours would be the same as the earlier model X100s.
Received 6,307 Likes
Helen,
If you can't find the source, this company is in London and should be able to help:
https://cars.newagain.co.uk/car-water-leak.asp
You can also Google "smoke test for car water leak" for more advice.
Good luck, and please keep us updated.
Stuart
Stuart
winstonsalemncxk (04-19-2018)
Received 1,975 Likes
Same as me, 2007 coupe... completely soaked behind drivers seat, about 1/8" puddle of water and rusty seat belt mounts. After removing carpet I couldn't find the source but I ended up sealing everything I could, every little dam spot where I thought water could come through. But none of that will matter if its somehow coming from above and draining down.
JimC64
03-02-2015 08:07 PM
