leaper on the rear lid
I have secured 2 more of the official Jaguar Leaper Badges that we see on the 2012 to 2013 MY XK/XKR. They were not available for the 2006 to 2011 model years.
These leaper badges really enhance the look of the pre 2012 XK/XKR's. This is the only mod I have made to my 2009, and it really enhances the rear end. I get lots of compliments.
Available on first come basis for $38.00 + $2.00 to ship in the USA. If any interest contact me directly via my private email here on the forum. I don't think these will last long. They are OEM size, metal and have the 3M super adhesive so no drilling is required.
They can also be plastic dipped before placing on the car for a custom look.
1 - Jaguar leaper badge left.........had 2...one being shipped to New Zealand.
OEM size, chrome, no drilling necessary. Goes on rear trunk lid. Same as XK/XKR on 2012 and beyond models.
See photo below of leaper on my 2009 XKR.
If interested send me a private email. This badge enhances the look of the XK/XKR pre 2012.
Badge can be plasti-dipped if you like before mounting for custom look or color.
Lots of Jag owners are doing this in Black.
See photo above of leaper on my 2009 XKR.
#30
As a new owner overwhelmed with my acquisition but not fully comprehending everything on the vehicle, I had to go into the garage one night to see if my 2007 XK Coupe had a leaper badge. I think seeing some pictures of other Jaguars spiked my curiosity. To my disappointment there was no badge. The badge adds a little panache for the price of lunch. The 3M tape install is easy to perform and durable. It is also easily removed if you need to.
I wouldn't drive my Jaguar without it.
Enjoy your new ride, these are amazing automobiles.
Lothar52 (12-06-2013)
#31
I'll be getting 2 more badges in and will be available in about 2 weeks.
First come.......first sent.
$38.00 +$2.00 shipping within USA.
Let me know if you have any interest and I will put your name at the top of the list.
#33
Temperature finally hit 60 so I took advantage of the warm day to install the Leaper Badge that I had recently acquired.
![](https://www.filesanywhere.com/FS/M.aspx?v=8c6b668e599ea7b7b4a3)
Simple install:
The adhesive will adhere to the surface better in higher temperatures. Try to do the install at 60 degrees or higher.
Determine where you want to place the badge. You can use regular scotch tape to test stick the badge and take a step back to make sure you are happy with the location. You only get one chance to stick it so make sure it is where you want it. During your test placement make sure the badge lays flat on the surface.
Since the trunk is slight curved where I selected to place the badge, I needed to slightly bend the badge by laying it perpendicular on a pencil and gently pressing the far edges of the leaper. The leaper must lay flat on the surface so in all likelihood you will need to bend it - just don't over do it.
You can mark the area where the badge will go with painters or masking tape. (Using Richzak's photo as a model I attempted to place the badge in a similar location with the bend of the front leg above the inside of the "G" and the bend of the back leg above the outside of the "U".
Make sure the area you have selected to place the badge is clean. After washing the area, I used a small amount of alcohol to clean the area and let it dry thoroughly.
Remove the 3M side of the tape and carefully the position the badge to fit the masked off area you created above. Press firmly with the palm of your hand for 30-60 seconds to make sure the adhesive adheres well. Remove the marking tape and take a step back to admire your new look.
Richzak may have badges available if you are interested in adding a leaper badge to your XK.
Simple install:
The addition of the badge really enhances the rear end of the tail. And nothing like..... good looking tail.
Thanks for the install lesson.
Yes, I have a few more leaper badges available.
#34
I have one Jaguar Leaper Badge available.
Let me know if you have any interest. Available for immediate shipping.
#35
I have 4 Jaguar Leaper Badges available.
First come.......first sent. I won't get any more after these are gone.
OEM size, chrome, no drilling necessary. Goes on rear trunk lid. Same as XK/XKR/XJ/XF on 2012 and beyond models.
See post #32 above for installation procedure.
UPDATE....I have only 2 available as of 2-5-2014.....first orders get the 2 remaining. Sent out 2 already today.
