Least aggressive lowering springs available ?
Looking for a little firmer ride and maybe slightly lowered. HR is a good company but only have 25mm springs available which might be too big of a drop.
anything else available ?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
These springs lowers 20mm.
Have no experience from them.
https://www.spires-st.com/product/xk...ering-springs/
It's 08 xkr convertible
__________________
Received 1,975 Likes
If you use the 'full' website from your phone, you see and post signatures, but its a bit harder to navigate that way (either everything is so tiny, or you have to keep sliding the image around to see everything).
Any tips on installing springs on the XKR? Ive lowered a few cars and they all have gone smoothly.
Theres not much info or guides on lowering the X150. Just curious if anyone had any tips. Ill take pics when complete. Im also changing the pads to EBC red, painting calipers to Black, changing brake fluid and changing out diff fluid. Lots to do!
Ill get alignment right after install is complete. I should
be installing them next Tuesday.
Thanks,
Joe
Thanks,
Joe
I'm a little worried that the 20mm might still be a little too agressive of a drop. Wish they had 10-15mm
Thanks,
Joe
Thanks,
Joe
you don't want it to snap!:-)
Lowering a car 10mm is meaningless, you won't even notice it! 20-25mm is perfect for our cars!:-)
This is mine with 20-25mm drop!
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20180408_085439_7481fc1eda706595d4b036b85c1f2e63ebaa5c3d.jpg)
I'm curious what you dislike about the factory setup? I've only hit the suspension limit once, coming off the interstate at 75+ and the nose pitched over excessively. Wasn't uncontrollable and it didn't push too much but it left me know we were at the limit of safe traction.
Lowering a car with different rate springs is not a good thing to do unless you also match the shocks to the new spring rate. Mismatched springs and dampers are not fun and will make your car slower and less controllable. Still, it might look a little better while it is being pulled from a ditch.
MarkyUK (10-27-2018)
I watched a slightly lowered newer 5.0 Mustang the other mornings commute and it did not look better in motion lowered. In fact it looked spine rattling stiff. It seems wheel well gap is the most common complaint why folks want their cars lowered. Taller profile tires fill the gaps and also allow it to ride better. Mine already has a lower roof line than pretty much any other car in the parking lot so... Just not seeing the point beyond a photo shoot. I care far more about the view and experience from behind the wheel than it posing as a trophy. Still get cars slowing next to me to see more even with clear coat peeling off.
SinF (10-26-2018)
For me it's a little about the look and more for performance in handling , because honestly our cars handle like a Lincoln , all flaoty and not very stable at high speeds. I love how soft it is though over bumps , but when car is pushed would preffer a more sporty and confident feel of the car
