LED Light Upgrade
#61
To add to the knowledge base, the XK uses the light fitting shown above that has the H11 bulb. The XKR uses the light fitting like mine. They are not interchangeable.
So has anyone with a pre-2010 XKR successfully used an LED H11 in their fog lights please? (Post 2010 models have air scoops where my fog lights are).
If so, then my car has a type of fog light fitting which it seems cannot be upgraded. The owner handbook has no mention of bulb type or bulb changing for the front fog lights, which feeds my suspicion that they are sealed units.
On this thread, MurrayG has an XK, which IS upgradeable and TexasTraveler has a later XKR which doesn't have front fog lights anyway (or at least not separate from the headlight unit).
Looks like I have to keep my fog lights 'yellow'.
Unless anyone else has any suggestions?
EDIT: I am wondering now if I can modify the XK light unit to fit the XKR. The fog light in the XKR is held by just two screws as far as I can tell without totally dismantling it. It should be fairly easy to make a bracket that matches the screw holes and then fit this to the XK unit using its own mounting holes. If you look at the photos of the two you can see what I mean. Maybe not worth it?
#62
Couldn’t you use these? Says they fit a 2006 XKR
https://rover.ebay.com/rover/0/0/0?m...2F223653012982
#63
I haven't envisioned a practical way to adapt any functional aftermarket sets to the XKR without hurting the front end aesthetics yet, which is too bad. I really really really want more light up there!
#64
I admit I miss the fog lights my '07 XK have while driving my XKR.
My 2006 has foglights so easy for me to connect.:-)
#65
#67
Anyone added a second backup light?
I would get much more useful light by changing the red rear foglight on my '08 XK to a second backup light. Has anyone done that? Wiring the light would not be a big problem, but I don't know what else is different between the two lights. Sockets? Lenses?
Radiance Red glows in the sun.
#68
Or buy the rear lights of a 2010-2011 which I've done and you'll have twin foglights and back up lights. The're full led so a nice upgrade! 😊 Search this forum and you'll find the threads.
#69
I though about it, but I would be looking more for a driving light rather than a fog light if possible. Not having control over where the light gets focused is also a personal issue for me, as I do not like blinding oncoming traffic just cause I think I look cool... (Not that that is your intent, but it is important to me that any light I produce be somewhat tuneable.)
Also, the XKRs are touchy about left/right airflow and IIRC they toss codes easily even with mismatched filters. I really want something that is functional
I have not done it with my XK, but I did buy the lamp from the UK for the conversion. I just bought the XKR before getting deeper into it and it went on hold.
I opted to buy a second fog light, rather than a 2nd backup light. Figured I would wire them both to fire when in reverse, as they are plenty bright enough, and if I didn't like it then simply add an under-bumper LED for something white.
#72
These are the brightest and best (IMO) bulbs that fit.
https://rover.ebay.com/rover/0/0/0?m...2F273853976857
#73
#74
Turn signal LEDs
eBay switchback indicators
#75
The simple ones?
This has been a great thread. Thanks to all who have helped with all the great advice. Interestingly, I am running into issues with the "simple ones"!
a) Visor/Vanity Lights - although I can pry open easily the plastic lens next to the mirrors, it is completely not clear how the bulbs can come out. Does anyone have a diagram/picture?
And, if I am not yet feeling foolish enough...
b) License Plate lamps - how does one remove the plastic lens covers. I have applied what I believe is a great deal of strength, they will not budge and I am fearful I am about the break them. Any advice on how to get to these lamps to replace them?
Lastly, with one of the inside/overhead lights replacement, I found that the contacts were very tricky with the LEDs I bought and took some contact "engineering" to make solid contact.
Appreciate any advice regarding these "simple ones!"
#76
The license plate lamps on my 2008 XKR are removed by gently prying at the side with a small screwdriver to 'unhook' the plastic clip which retains them. You are right to be careful - I snapped off one of the plastic clips on one of my units and had to buy a replacement, which is expensive for what is a bit of moulded plastic. My advice is to gently warm the plastic unit before attempting to remove it - this will slightly soften the brittle plastic and make it easier to remove safely. Use a heat gun on a low setting or a hairdryer.
A quick google shows that there are two types of license plate units - the 'push fix' type I have:
Number Plate Lamp LH (C2P3668) (sngbarratt.com)
On the photo in the link you can see the two retaining prongs on one side of the unit quite clearly. The bit that you have to pry is the opposite end of the unit. I can tell what it is from the photo but if you haven't seen one before, you may not be able to.
Or the 'screw fix' type - IDK which your car may have.
Jaguar X150 XK Number Plate Lamp|British Parts UK
It seems that the push fix type were for cars from 2006 - 2010 model years (that is UK MY, the US MYs may be slightly different).
#77
Barnsie - thank you! Last night I was thinking that the LEDs may be too harsh (it's for the Mrs who uses the vanity mirror, honestly I don't think I have ever used the one on the driver side) and perhaps your advice is the best - to keep the bulbs as is.
As for the license plate lamp covers, thank you for the confirmation. I will use a heat lamp this weekend first. BTW - we have the same "push fix" type on our '08 XKRs!
All the best and thanks again!
#78
You're welcome. Good luck!
#79
Thanks, I just replaced my license plate 194s, with LEDs about a month ago and immediately noticed a dim glow even with the power off. Three days later my battery was dead. Had never had a battery issue before even after leaving the car setting for weeks at a time. This was the only change I made to date to the xkr. Have you noticed any dim lights with your LED installs?
#80
Haven't noticed a flicker on the new ones and they don't stay on dimly after I turn off the lights. So far so good....
