Let's talk about catch cans
#64
#65
But I am considering fabricating a can and placing it there. Much cooler in that spot and would condense the vapors faster. I'll try to take a pic when I have my headlamp off.
pwpacp (07-29-2019)
#66
Here is the amt of vapor trapped and drained at my first oil change. It was actually quite a bit and looked like the baffle was over-saturated (not sure if that's the right word).
I will reduce the drain interval from 6000 Miles (@ the oil change) to 3000 Miles.
Also, the rubber 'PCV rated' hose is swelling and even shows condensation. It is starting to stink in the engine bay and even into the cabin. I will have to replace the rubber tubes with full length clear tubing. That seems to be holding up well.
Quantity @ ~6000 miles:
#67
#68
#69
https://lolaproducts.com/products/co...saAt7FEALw_wcB
jahummer (01-12-2021)
#70
Unless you have some clear plastic tubing thats immune from the effects of petroleum products and it too will be very slowly attacked from the oil and by the strong vacuum on the PCV line. It will eventually collapse. At least that’s my experience. I have a moroso Catch can mounted in my STR but I have not yet connected any lines to it as I can’t bear the thought of destroying or cutting the hard plastic line that goes to the PCV valve. Does anybody know where I can find two fittings that will mate to either the PCV valve or inlet fitting at the throttlebody that will accept a similar size hose that I can run to my Catch can?
#71
I know this is an old thread, but here's what your intake manifold looks like at 105,000 miles with no catch can. The valve on the right has a dislodged valve seat, which probably has nothing to do with the carbon buildup. The valve on the leftis barely visible because it's covered with 105K miles of oil that has been cooked off by the heat of the engine.
When I get my engine rebuilt, I'm definitely installing a catch can.
#74
#75
I'm just removing the left head, having the seat replaced, and reinstalling the head. Depending on how difficult it is to remove the head, I might also remove the right head to have the carbon cleaned from it.
Cee Jay (06-30-2021)
#76
Imo catch cans is a must on 4.2 cars. Have yet to install ony 5.0 though
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
