Let's Talk Wheel Gap
Old 02-09-2019, 04:48 PM
viper1996's Avatar
Default Let's Talk Wheel Gap
Lots of threads on lowering, wheel spacers, springs, etc. I would like to hear the consensus of XK owners that are happy with the "LOOK" of the standard ride height...Ride, camber, rubbing, scraping facia, etc to be excluded in topic. Base your thoughts on looks only! My thoughts are the stock height is to high and degrade the look of the sleek elegant body style...Your thoughts please.
Old 02-09-2019, 05:12 PM
pwpacp's Avatar
I could see mine a bit lower for that sleeker look, however; that would present an issue for my ground clearance which makes it a no-go for me.
Old 02-09-2019, 05:23 PM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
I'm happy with the OEM design Viper1996. Lower looks great but it's not for me.
Old 02-09-2019, 05:36 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
It is standard height is good for me. would look a little better lower but then ground clearance would be negatively effected.
Old 02-09-2019, 06:15 PM
09XFSuper's Avatar
OEM ride height on my ‘09 XKR Portfolio is just right in my eyes and I usually lower my cars with Eiback Pro-Kit springs as I consider their Sport Lines too low. I like about 2 finger with clearance between fender lip to tire.
Stock springs
Queen and Country (02-10-2019)
Old 02-09-2019, 08:16 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
I prefer the wheel arch to neatly frame the wheel. To my eye lowered X150's look odd.
Old 02-09-2019, 08:24 PM
capitol1's Avatar
My Personal Preference.................. A Lower Profile.
Old 02-09-2019, 08:30 PM
Received 4,458 Likes on 2,427 Posts
XKR-S springs in mine which are supposedly 10mm lower at the front and 15mm lower at the rear. Looks just about right to me.
Old 02-09-2019, 08:32 PM
Also
Old 02-09-2019, 08:38 PM
capitol1's Avatar
Your Right! Here's Mine!
Old 02-09-2019, 09:00 PM
Sean W's Avatar
Here's mine from the dealer before I bought it - stock set up
Old 02-09-2019, 09:11 PM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
Attachment 217628
By comparison, mine is stock. I don't see much of a difference. And, yes they're both Shadow Grey, just a difference in exposure.
Old 02-10-2019, 12:17 AM
Queen and Country's Avatar
Received 2,383 Likes on 1,609 Posts
This car is not designed like a BMW M3.
Its a throwback to the etype, and they have mimicked the massive 'in-set' the front wheels had on the Etype.
No way will you ever fix that and keep the steering geometry.
BTW the Etype had no gap.
Slammed but front fender is a mile away
guy (02-10-2019)
Old 02-10-2019, 01:51 AM
peterv8's Avatar
Adamesh springs!:-)
Old 02-10-2019, 03:40 AM
MarkyUK's Avatar
Thanks to the bodykit on mine it already sits lower, in the case of my 2014 a garage that services a friends 2010 XKR can't get mine up on their lifts because it is too low, approx 20mm lower
Will try to take a better picture, imo it's too low as keep catching the lip spoiler on curbs etc
guy (02-10-2019)
Old 02-10-2019, 10:40 AM
viper1996's Avatar
I have the H&Rs on mine and it sits a little to low to me...I have 15 mm spacers all the way around. I think the Amadesh or Spires at 25mm look the best to me. opinions? H&Rs 33mm
Old 02-10-2019, 10:43 AM
viper1996's Avatar
Originally Posted by peterv8
Adamesh springs!:-)
Are you using spacers as well?
Old 02-10-2019, 10:50 AM
RobGardnerBlack's Avatar
Same problem here, the 2014 is just that bit lower due to the styling and makes for more issues driving it; sat beside the older XKR it does not appear lower but I have not gotten the spirit level out to check,
Old 02-10-2019, 11:05 AM
peterv8's Avatar
Yes, 20mm front 15mm rear
YOU HAVE 2 XKR's!?
Nice!
Old 02-10-2019, 01:46 PM
Old Radar's Avatar
I really appreciate the aesthetics of the nearly perfect concentric circles formed by the rim, tire, tire gap and wheel well rim. Lowering skews the gap and cancels the entire aesthetic effect. Besides, if I lowered it, I would risk a daily threat from the ridge in my driveway!
Of course, many will have different opinions of the aesthetics of the XK--especially the XKR-S owners--but then, their preferences lean more to the aggressive sport look than simple classic lines--otherwise they would have bought an XK (and if I leaned that way, I would own an XKR-S). In fact, I normally have difficulty picking out the lines of the XK when looking at an XKR-S.
Beyond the need to tinker, the more I read these type of threads, (lowering, larger rims, HP increases, body mods, etc.) the more I sense a certain desire to have the car seem more aggressive--to move it across the scale from XK to XKR or from XKR to XKR-S. You'll notice I said "across the scale" versus "up the scale" because, to me, the latter would imply a sense of increasing desirability that I, personally, do not feel. There is certainly nothing wrong with striving for something more/different/better/shinier than what you currently have, but at least for me and cars, I've always taken the route of finding something I truly enjoy looking at and driving the way it was designed versus trying to change it into something it wasn't.
I've owned my Toyota Supra Turbo for 30 years because it was exactly the car I wanted back in 1989. Up until a couple of years ago it was completely stock. Only when parts became virtually impossible to obtain did I do a few mods. For example, no one, and I mean no one, makes electronically adjustable shocks that work with the Toyota Electronic Modulated Suspension (TEMS), so I was forced to find an alternate solution--which turned out to be manually adjustable coil-overs. Did they lower the car? Yes. Did lowering look better? Maybe. Would I have considered lowering if I could have found TEMS-compatible shocks? Not for a second.
So, to bring this back to XKs,
If you love to tinker, then tinker.
If you would love for your XK to be/look/perform like something else, change it.
If you love your XK the way it was designed, relax and enjoy it.
pwpacp (02-10-2019)
Quick Reply: Let's Talk Wheel Gap
