Looking for stock or aftermarket cats
Magnaflow Performance Polished High-Flow Catalytic Converters - JEGS
Magnaflow is kind of the standard. Anything "better" is going to be niche and significantly more money.
guy (09-27-2013)
replaced all the coil already , now just a failing cat
i was even considering running straight pipe, have you ever heard of anyone doing that not sure how well the temp would be reglsted with the 02 before and after the existing cat , do you have a model number for which magnaflow cat ? thanks for the help
The 02 sensor after the Cat would be eliminated or a dummy plug put in to keep the CEL light off. You WILL smell gas if you remove the Cats... I did this in my last car which was far more sports car oriented than the GT/luxury Jag.
I don't have a model number... but high flow cats will make a bigger difference to performance than an exhaust since they will by far free up more airflow. In the car industry it's taboo; and even illegal in some states, to modify working cats.
SoCalJagS
09-27-2015 09:20 AM
