Low Fuel warning with full tank
Filled the car up yesterday morning and set off to a XK club breakfast meet yesterday morning. I'd done about 45 miles cruising the motorway at 70 and saw "LOW FUEL" warning on the dash, and the bar gauge showed totally empty. I pulled over and checked under the car and in the engine bay, no sign or smell of leaking fuel and the engine was still running fine. Switched off for a few moments and back on again and the gauge was back to normal and showing plausible values whenever I looked at it, given the miles I'd done.
I haven't checked for codes with SDD yet but just wondered if anyone else had had seen this and done any reading on this?
From the manualFuel Level Display
The fuel level display is a linear LCD display to show the usable fuel tank contents. The level display is active at all times when the ignition is on. Low fuel level is displayed as a LOW FUEL LEVEL message and an amber warning triangle in the message center.
The fuel level is obtained by fuel level sensors in the fuel tank. These are monitored by the auxiliary junction box software and their output resistance values, corresponding fuel quantity, are transmitted to the instrument cluster on the medium speed CAN bus. The instrument cluster uses the two level sensor signals to calculate the fuel tank contents. This calculation takes into account fuel movement in the tank to display a steady fuel quantity in the LCD.
The fuel level information is transmitted on the medium speed and high speed CAN bus for use by other vehicle system modules.
Not much to add. Failing sensor possibly but likely an anomaly. Kind of guessing without a code.
So this happened again yesterday, funnily enough I was actually looking at the display when it changed from showing 160 miles remaining range and about 2/3 of a tank to zero remaining fuel and the LOW FUEL warning. I checked the car for codes using SDD last night and found two (although the mileage shown when they appeared was probably the mileage done when they came up first time a few months ago), they are as follows:
B1A75-1C - Fuel Sender 1 Circuit
B1A76-1C - Fuel Sender 2 Circuit
A bit of google searching reveals there is a Land Rover TSB which apparently applies to the 2014 Range Rover Supercharged (I guess this will be the 5.0 V8 S/C also) which describes this exact issue; sudden and incorrect warning of zero fuel.
Does anyone have access to any sort of repository of these TSBs and able to share the details/contents/suggestion as to possible fix? I'm hoping it's not "replace the senders" as they're in the tank, which means exhaust off, driveshaft off, subframe off etc...
8bit (08-14-2019)
So if it just means that every once in a while the fuel gauge will stop working until the car is switched off and on again then it's not worth the time and effort required to fix it. Saying that, given that the shutdown/startup restores it I'm slightly leaning towards some sort of software issue rather than an actual, physical fault.
davidladewig
06-12-2017 09:14 PM
