Lower driver panel removal - 2007 XK
1 Post
I'm trying to repair a noisy temperature sensor motor. It is located behind a small grate just right of the steering wheel. I have seen info here describing how to reach up from under the dash to get to it, but I believe that information is for a <=2006 XK, and that it is not valid for a 2007+. The gaps are simply too small for anyone to reach through to the device. I have tried to remove the lower panel but can't figure it out.
I removed the lowest (furry) ceiling plate over the pedals. Then there are two torx bolts. Then I removed the leftmost panel and another bolt behind there. From this point, I'm stuck. Any help would be appreciated.
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Instructions for the lower panel and sensor are attached. Hope they help.
Wolfy
05-28-2024 08:06 AM
