Lowered! handles great! but too much Camber in the rear. Camber plates available?
Old 05-28-2019, 04:46 PM
AlexJag's Avatar
Sponsor
Default Lowered! handles great! but too much Camber in the rear. Camber plates available?
Hi guys !
Got Eibach 20mm lowering springs installed
The car handles so much different now, more crisp and precise steering with much less body roll.
Now the problem is in the rear there is -2.2 negative Camber on one side and -1.3 on the other
Anyway to adjust this?
I tried finding Camber plates that are adjustable , so far could find none.
Thanks for any input!
Old 05-28-2019, 05:44 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Old 05-28-2019, 06:16 PM
AlexJag's Avatar
Sponsor
Originally Posted by Cee Jay
Picture of what, the negative camber?
The following 2 users liked this post by AlexJag:
David Vincent (07-02-2023), Jaggyx (11-14-2022)
Old 05-28-2019, 06:41 PM
Cee Jay's Avatar
Yes. Camber is cool.
Oh, wait, no, not that. Maybe this instead;
Originally Posted by AlexJag
Hi guys !
Got Eibach 20mm lowering springs installed..........
Course, seeing goofy stuff is always fun also.
Old 05-28-2019, 06:52 PM
jahummer's Avatar
Received 2,367 Likes on 1,482 Posts
On track, negative camber is a good thing! You can adjust toe and caster to get it closer, especially where you have over -2.2 but no one makes plates or top control arm extensions. Personally I have over 2 degrees negative on all 4 corners and it turns like it's on rails.
File Type: docx
Old 05-28-2019, 07:35 PM
AlexJag's Avatar
Sponsor
Jeremy the problem is left rear is -1.3 and right is -2.2
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
Old 05-28-2019, 08:19 PM
Ranchero50's Avatar
Should be the same side to side. Per any difference I assume the shop would need to loosen all the suspension fasteners and see if they can get the sides even.
I also assume you could machine and install a 1-2 degree angled wheel bearing spacer but I'm not sure how much much difference the caliper would allow.
Old 05-28-2019, 10:25 PM
steve_k_xk's Avatar
Received 1,548 Likes on 895 Posts
Actually got my spec sheet at work and I'm running eibach 20mm lowering springs on a side not you don't realise how unimpressive the handling is on these cars until you put the firm spring in
Rear camber
LH -01.56
RH -01.64
So yes I also do have negative camber which is correct and it's well with in specs
Alex yours is just within specs max camber allowed is -02.25
Attached Thumbnails Lowered! handles great! but too much Camber in the rear. Camber plates available?-1559100537545.jpg
Old 05-29-2019, 11:38 AM
AlexJag's Avatar
Sponsor
Rear camber
LH -01.56
RH -01.64
Steve my problem is that left to right it's not the same at -1 difference between the two sides so that definitely must be addressed and - 2.2 is pushing it and it will hurt tire wear most likely
Old 05-29-2019, 04:10 PM
steve_k_xk's Avatar
Alex there is definitely adjustment in the rear I had mine adjusted from
LH -01.49 to - 01.56
RH -00.83 to -01.64
Old 05-29-2019, 06:12 PM
AlexJag's Avatar
Sponsor
RH -00.83 to -01.64
Steve there is no adjustment in the rear I had to alignment shops check this
Old 05-29-2019, 07:39 PM
steve_k_xk's Avatar
That's a good thing you didnt let those two particular shops touch your car
Off the top of my head I know for certain there is a toe adjustment rod
Would have to put my car back up on a lift to see what other adjustments are there , however the camber can definitely be adjusted Alex
Old 05-29-2019, 07:46 PM
Cee Jay's Avatar
Anything can be done, it just depends on how involved you want to be in the task. Looking at the parts diagram, it'd be a fairly intensive modification;
Old 05-29-2019, 09:01 PM
Ranchero50's Avatar
Honestly a 1 degree difference should be easy to comp by loosening the hardware and tweaking the bushings. Probably just need to do the lower a arm to saddle bolt. Loosen it and shift the bottom of the carrier inboard as much as it would go. We do similar things all the time for shaft alignments on machines.
AlexJag (06-13-2019)
Old 05-29-2019, 10:14 PM
jahummer's Avatar
As I said above you can adjust to compensate for camber you just don’t have camber specifically. I’ve gone anywhere from about -.95 to over -2
Old 05-30-2019, 02:01 AM
AlexJag's Avatar
Sponsor
Steve all that can be adjusted in rear is toe, no camber adjustments.
Old 05-30-2019, 02:03 AM
AlexJag's Avatar
Sponsor
Caster on the rear? It's only front right? Only toe is adjustable in the rear as far as I know
Old 05-30-2019, 08:05 AM
steve_k_xk's Avatar
That toe adjustment rod will adjust toe correct but it will also adjust the castor also .
Old 06-02-2019, 11:37 AM
jahummer's Avatar
Alex, Take a look at my thread when I installed the Eibach springs, you'll see pics of the car and alignment specs before and after. Something important to keep in mind regarding negative camber, while it improves cornering and track performance significantly, on the street tire wear may be impacted and more importantly steering will be affected, it will still drive straight but will require more steering input to maintain a straight line, especially under throttle, on cambered roads.
https://www.jaguarforums.com/forum/x...ry-way-163176/
Old 06-13-2019, 10:57 AM
BlackKat's Avatar
Check the bushings, particularly the lower control arm to knuckle bushing. If this goes bad you will get bad camber. Happened to me and wore out my tire inners.
Quick Reply: Lowered! handles great! but too much Camber in the rear. Camber plates available?
