Lowered! handles great! but too much Camber in the rear. Camber plates available?
Hi guys !
Got Eibach 20mm lowering springs installed
The car handles so much different now, more crisp and precise steering with much less body roll.
Now the problem is in the rear there is -2.2 negative Camber on one side and -1.3 on the other
Anyway to adjust this?
I tried finding Camber plates that are adjustable , so far could find none.
Thanks for any input!
The following 2 users liked this post by AlexJag:
David Vincent (07-02-2023),
Jaggyx (11-14-2022)
On track, negative camber is a good thing! You can adjust toe and caster to get it closer, especially where you have over -2.2 but no one makes plates or top control arm extensions. Personally I have over 2 degrees negative on all 4 corners and it turns like it's on rails.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
Should be the same side to side. Per any difference I assume the shop would need to loosen all the suspension fasteners and see if they can get the sides even.
I also assume you could machine and install a 1-2 degree angled wheel bearing spacer but I'm not sure how much much difference the caliper would allow.
Actually got my spec sheet at work and I'm running eibach 20mm lowering springs on a side not you don't realise how unimpressive the handling is on these cars until you put the firm spring in
Rear camber
LH -01.56
RH -01.64
So yes I also do have negative camber which is correct and it's well with in specs
Alex yours is just within specs max camber allowed is -02.25
Rear camber
LH -01.56
RH -01.64
Rear camber
LH -01.56
RH -01.64
Rear camber
LH -01.56
RH -01.64
Honestly a 1 degree difference should be easy to comp by loosening the hardware and tweaking the bushings. Probably just need to do the lower a arm to saddle bolt. Loosen it and shift the bottom of the carrier inboard as much as it would go. We do similar things all the time for shaft alignments on machines.
AlexJag (06-13-2019)
That's a good thing you didnt let those two particular shops touch your car
Off the top of my head I know for certain there is a toe adjustment rod
Would have to put my car back up on a lift to see what other adjustments are there , however the camber can definitely be adjusted Alex
Caster on the rear? It's only front right? Only toe is adjustable in the rear as far as I know
Alex, Take a look at my thread when I installed the Eibach springs, you'll see pics of the car and alignment specs before and after. Something important to keep in mind regarding negative camber, while it improves cornering and track performance significantly, on the street tire wear may be impacted and more importantly steering will be affected, it will still drive straight but will require more steering input to maintain a straight line, especially under throttle, on cambered roads.
https://www.jaguarforums.com/forum/x...ry-way-163176/
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/130412d1463864706-finally-lowered-xkr-eibach-perfect-every-way-img_9004.jpg)
