Lowered! handles great! but too much Camber in the rear. Camber plates available?
Received 2,190 Likes
alex, take a look at my thread when i installed the eibach springs, you'll see pics of the car and alignment specs before and after. Something important to keep in mind regarding negative camber, while it improves cornering and track performance significantly, on the street tire wear may be impacted and more importantly steering will be affected, it will still drive straight but will require more steering input to maintain a straight line, especially under throttle, on cambered roads.
https://www.jaguarforums.com/forum/x...ry-way-163176/
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/130412d1463864706-finally-lowered-xkr-eibach-perfect-every-way-img_9004.jpg)
also a spring with a different spring rate will lower ride height and increase negative camber as will a collapsed spring isolator(foam part) spring rides under. Im assuming these were changed. The other thing to look at is the subframe in relation to the underbody. I have seen subframes kicked over in the under body mounts and this gives less camber on 1 side and more on the other. You should see no telltale marks where the subframe bolts mounts meet the body that would indicate shift usually from a hard curb/pothole impact. If so loosen the bolts and pry back in place, tighten bolts and get another alignment. There is no camber adjustment in the rear only toe and this only very slightly affect camber. Nothing close to what youre looking to change.
I know your spring are new but that does not meen theyre evenly rated either from manufacture or oops wrong part in the box, see this every now a then. Update us
Emergency repair ended up being a LS swap to open 3.58's. Nailed it in 2nd going through a short tunnel this morning and it spun just the slightest bit. The processor didn't pull any power out that I could tell.
The following 2 users liked this post by steve_k_xk:
AlexJag (06-17-2019),
Ranchero50 (06-17-2019)
hey brutal, one thing i noticed during my diff swap was the front subframe bolts has a whitish liquid come out once the bolts were loosened. Were these dampened at one time? I didn't mess with the backs as i just removed the k support structure to get it out of the way.
My real concern is I'd rather a tire slip a little versus overload the ring and pinion which IMHO are a little small for a 420 hp powerplant with big block levels of torque. Heck, back in the '60's Ford ran 9" rears on big blocks and skinny tires.
I did think about this thread during the diff swap and didn't really see any looseness in the connecting joints other than the subframe to body mounts and I want to say that the suspension bolted to the subframe (except for the shock / spring package) so I'm still at a loss.
jchou
09-13-2013 09:58 PM
