Lowered and Rubbing?
I just had H&R 35mm springs and 15mm spacers installed on my 2013 XKR. I changed the springs not as much for looks, but rather to take the "bounce" out of the stock rear XKR springs.
After installing the spacers I immediately heard a very noticeable rubbing noise coming from the drivers rear wheel well. After examining the area I found that the wheel well liner was not fitted properly and was rubbing on the tire. I tried to relocate the liner but it moved the following day.
Today I came up with what appears is finally a permanent solution. If you have any rubbing issues you can correct the problem quite easily.
On the bottom edge of the liner where it meets up with the fender contour there is a return molded into the liner. It is only between .250" and .375" in width. If you remove this lower edge of the liner (utility knife worked very well) it will increase your wheel well clearance. I then applied a light brushing of contact cement to both the inner fender and the liner along the lower .750" or so. The result completely eliminated the rubbing issue.
I know that most who have lowered and added spacers did not experience any rubbing, but if you are lucky like me, its an easy and clean fix.
By the way, the bounce is gone and the car actually now feels more comfortable to me and the handling has improved.
ive noticed the wheel well liner being rather...not properly installed myself...even on the XKR-S. Had to use my hand and pound it back into place correctly in the rear well in a few places. The screws are there where they need to be but just not pushed in as good as it should. On my G37s there is plastic in the wheelwell but no liner that feels really like carpet like the XK...wonder why they just didnt use high end plastic in the wheelwell?!?!?!?!?
It is actually a rigid inner liner with a carpet-like covering over it. Problem is it is so thin it doesn't seem to hold its shape well.
You just made my day! I've been driving gingerly all weekend as I thought the fenders may be rubbing.. I cut off .25 inches of the liner on the left side only and all the rubbing is gone unless I make a hard left turn under heavy acceleration. Now the left side still rubs so that confirms the lining. I plan on cleaning it up today with an xacto knife and sealing it with silicone to a quarter panel. Now the car is perfect at this ride height! Thank you PCXKR! Also note there is a larg staple near the center of the wheel arch that must be removed. This staple keeps the front and rear liners together but also make the liner quite a bit thicker at the point it needs to be the thinnest. Once sealed with silicone this is no longer an issue.
SD96XJ6L
11-05-2015 10:47 AM
