Lowering Springs for 2010-Plus XKR (Not H&R)?
Old 11-04-2017, 08:40 PM
multistrada74's Avatar
Default Lowering Springs for 2010-Plus XKR (Not H&R)?
Gents, I had H&R springs on my 2007 XKR and they were great. I just bought a 2010, and love the much improved suspension, but the ride height is just not my cup of tea.
From H&R's web site, it looks like their springs are no different for the 5.0's as they are for the 4.2's, which is a problem, as the OE spring rate on the 5.0's is higher than the 4.2's. I would not want to put a softer rate spring on the car than stock, just for the sake of lowering it.
Does any spring manufacturer make springs specifically for the 2010-2014 XKR? If not, I will forgo lowering the car.
Thanks in advance to anyone who can accurately answer this question.
Old 11-06-2017, 05:24 PM
No one? Nothing?
Old 11-06-2017, 05:49 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
I'll post, but I have no idea about these springs. At least you now know your thread is active!
Datsports (11-09-2017)
Old 11-06-2017, 06:44 PM
Received 2,646 Likes on 1,822 Posts
Arden have lowering springs for the 5.0 litre cars:
Jaguar XK Fahrwerk
As do Adamesh:
https://www.adamesh.co.uk/jaguar-xk-...5mm-4319-p.asp
You might want to ring Adamesh in the UK and see if they have a suggestion on a vendor for the 5.0 litre cars.
Old 11-07-2017, 06:35 AM
Mufc's Avatar
Buy the springs from Jaguar. XKR-S springs are lower and designed for the car
guy (11-05-2022)
Old 11-09-2017, 08:37 PM
Jaguar XK Fahrwerk
As do Adamesh:
awesome, tnx mate.
Old 11-09-2017, 08:41 PM
Originally Posted by multistrada74
awesome, tnx mate.
uuugggg, both are not for the 2010-plus.
Old 11-09-2017, 09:06 PM
That's odd because it looked like they did have springs available for the later 5.0 litre cars. Arden's website says from 2010 on.
Perhaps the XKR-S springs would work?
Old 11-09-2017, 11:15 PM
Datsports's Avatar
i think you'll find the h&r spring is up rated from stock 4.2 in any case .
so in that case they might be lower with the same rating or beyond the 5.0 springs .
have you taken the time to ask them .
i know the h&r s type springs are heavier rating than stock STR.
might be worth an ask . from what ive seen h&r only make upgrades .
Old 11-10-2017, 03:03 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Dynamic Pack / R-S springs are stiffer than stock 5.0 (front 28% stiffer, rear 32%) and the car rides 10mm lower. That may not be enough for your taste, but a Dynamic Pack car definitely has a visibly lower stance.
Old 11-12-2017, 12:30 PM
bigdhenderson's Avatar
When I purchased my 2010 xkr it had h&r lowering springs on it. I took them off in favor of xkr-s springs, and like them much better. The h&r springs were too low for all the driving i do.
Old 11-12-2017, 07:36 PM
yea, i'm waiting on a reply from them. hopefully.
Old 11-12-2017, 07:41 PM
yes, you are correct on those numbers. my question is....are the shocks on the dynamic pac and R-S cars calibrated to work with the stiffer springs? if they are, I wonder if my regular XKR shocks will work with them properly. nothing worse than too little dampening on a stiff spring.
Old 11-12-2017, 07:42 PM
yes, you could be right. I have sent them 2 emails and I have had zero reply. will call tmrw and see if I can get a tech on the phone.
Old 11-12-2017, 07:49 PM
I loved the look and the ride quality on my 2007 with the H&R's (although they seemed noticeably softer than the stock springs on my 2010), but as these cars have zero camber adjustment (pretty silly that they don't), I killed inner-tires from the almosy 2.0 of neg-camber. don't want to do that again.
Old 11-12-2017, 07:52 PM
do the shocks feel like they manage the stiffer rate xkrs springs well? I don't know whether then dynamic pac/xkrs shocks are calibrated for the stiffer springs.
Old 11-13-2017, 05:36 AM
Ngarara's Avatar
Since all the damper settings are driven by software, it's just a mapping change to alter the characteristics. I believe the Active Dynamics settings are recalibrated on the Dynamic Pack & R-S - whether that included changing the level of damping I don't know, but I suspect it did.
So, yeah, the standard damper settings may not be fully tuned to work with stiffer springs. Unless, of course, the system is truly dynamic and learns how much damping is needed by tracking ride height, roll, pitch, yaw, etc. I know it's pretty smart, I just don't know how smart...
Old 11-13-2017, 11:08 AM
dcmackintosh's Avatar
I'd actually like to try XKR springs on my XKR-S, although I'd want to hang onto those so that I could return it to stock. If anyone has a set to sell, especially in the PNW, get in touch.
Are there any coilover options? I'd love to be able to try different spring rates to balance the car, and adjust the ride height.
Old 11-13-2017, 12:24 PM
I think my shocks are toast anyway (got some front end clunk over big bumps/rr tracks) from having the h&rs on there as long as I did, so I can't tell you an honest opinion.
Old 11-14-2017, 04:07 PM
do you think the 1.3" drop from the H&R's did the shocks in, or just mileage? they shouldn't damage the shocks. in theory, at least.
Quick Reply: Lowering Springs for 2010-Plus XKR (Not H&R)?
