Lumbar Support Deflating
Haven’t tested the passenger side, but the lumbar support is deflating slowly pretty much right after I inflate it all the way or inflate it at all. It doesn’t deflate entirely unless I adjust it to minimal inflation. It deflates within 30 seconds or so after I inflate it. Also the memory setting to recall my preference of it inflating does nothing. Any thoughts? I feel like if it was just a leak, then it wouldn’t also be not recalling it to inflate. It does inflate all the way if I do it manually with the adjuster. But it won’t stay inflated. I haven’t tried the side bolsters but I think they have stayed. Everything else works on the seat.
All that said, I've never opened up the seat to look at the components like the lumbar bladder, so maybe there is a mechanical reason at the heart of things.
Sorry if I wrote my response in a confusing way. What I'm saying is maybe the memory value for the lumbar is actually stuck at a lower setting, and for some reason the "activate" memory function just keeps triggering. Bottom line: the details from the original post seem like an electrical issue related to the seat settings or memory settings, as opposed to a leak. The original post says that the lumbar bladder doesn't seem to deflate completely. Seems like it would if there were a leak.
correct. I appreciate you’re suggestion tips and am going to try them. Yes it’s basically like if 3/3 was entirely inflated (about to burst) and 0/3 was completely deflated like your lumbar is hunch-backing and getting sucked into the seat almost, mine seems to go to a solid 1/3 and remain there for good. If I then go and try to deflate it further, I will hear that hissing noise and the lumbar will go all the way to 0/3.
If there's anything I've learned in the short time that I've been on this forum, it's that these cars are overall mechanically reliable if you take care of them. Buuuuuut... they also seem to have a good number of electrical gremlins that manifest themselves in some crazy ways.
Update us on what you discover.
bgpenguin21 (09-16-2023)
The following 2 users liked this post by Sean W:
bgpenguin21 (09-18-2023),
McJag222 (09-18-2023)
The following 3 users liked this post by Cee Jay:
relinuca
11-14-2010 08:08 AM
