Lumpy running xk 2007
Hi guys and girls I have a 2007 xk and have an issue. When travelling at about 70 to 80 mph on a motorway the engine runs lumpy almost feels like something is slipping. It's not revving high or anything just lumpy and not smooth. I am concerned about this as could be a big problem have any of you come across this before?
No check engine light? It could have codes stored in the computer even if it doesn't throw the light. Only a shop can tell you that.
Does it run rough or cut out when you accelerate? Have you ever changed the fuel filter? It's really easy to do because it has quick release connections on both ends. Otherwise it could be a lot of things.
Govtslug
Govtslug
Unclebuck (10-13-2015)
Based in the fact that you've given us almost zero in terms of information on your car, it is my professional opinion gathered from years of mechanical expertise that "it may be something or it may be nothing". Never heard of a description of a car being "lumpy". Provide us with miles, last tune up, what has done or not done at your last maintenance, any code readings, has the car be driven regularly, is ot all stock, etc and maybe we can help or pay a mechanic his fee
Thanks for the reply yeah no engine management light has come on it's quite odd it doesn't cut out just isn't smooth if it had a cam belt I would say it feels almost like that was slipping but it had a chain hence why I was a bit confused. Has been serviced regularly on time. I don't drive the car every day but not sure if that matters
So all good the lumpy running is in 6 but assuming that as my XK is and auto. I had it serviced and to solve the problem they reset the power control module adaption and cleared fault codes and didn't share codes with me from what I understand that is like a reboot as I say I am no mech. It seems to have solved the problem but will give it a few more drives until fully convinced. The problem seemed to be related to a specific speed range 70 to 90 mph when cruising at that speed it didn't seem to affect the rpm although it was only a slight rough running so the difference in rpm might be minimal it was more I could feel it through the accelerator pedal I.e. The power dropping of slightly
I'd start with the obvious - new plugs (probably not that or you'd get a misfire code), fuel filter, take a look at the air cleaner, run it at high RPM's for a little bit in case it was bad gas or just an anomaly. Being there was no error code that helps a bunch, maybe try some Seafoam couldn't hurt
kouichi fujise
10-07-2015 01:33 PM
