Main screen not booting up
Hi I'm having an issue with the Main screen not coming on when the car is started, all I get is the Jaguar logo on the screen and no heater or audio controls, no amount of button pressing will bring it back on.
Turning off the car and locking it up will bring it back on next opening cycle but the issue does seem to be getting worse/more frequent. When the system does boot up it works absolutely fine.
Any ideas?
Thanks Ian
Any ideas?
Thanks Ian
Agree with other comments...Start with the battery.
I just went through this very thing in the last few weeks. The screen got stuck on the logo ever so often after start up. Then it got more frequent. If the radio or CD was playing before I shut it down, it would be playing when I started and now way of stopping it, changing volume etc.
Then finally the car started to have starting problems if I didn't drive it for a day or two.
I changed the battery last weekend and everything is normal again.
So, in my case the symptom was an early warning sign of battery fail.
I have had similar problems, but I have discovered that the connections to my bluetooth module (especially the pin one) are loose, and when I replug it in more securely, i get full function of the screen (except for bluetooth use as it's not working). When I unplug the bluetooth module in the trunk next to the battery, the screen is completely black and non-functional. I think bluetooth module is located in a different area on your car, but you might want to check connections.
Many thanks for the replies, the battery was replaced last year and is still in good condition according to my voltmeter. The bluetooth module failure is interesting as bluetooth phone connection packed in a couple of weeks ago so maybe there is some issue there. Car was fine today all working well.
Thanks again
Thanks again
Here's the poor man's battery tester, no voltmeter required.
![Icon Oldskewl](https://www.jaguarforums.com/forum/images/smilies/icon_oldskewl.gif)
Before starting the engine (and with your foot off the brake pedal), turn the headlights on high beams and then count to 15. Then press the START button and put your foot on the brake pedal. If it starts right up, your battery is good.
Otherwise, it's not so good.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
ralphwg (01-29-2022)
Thanks again
Thanks again
Thanks again
Thanks again
The auto chain store that sold it to me last year pointed out it was not a common sale and a big battery.
When I had it checked last week, it actually tested as "Good", but they did point out it was a 2016 battery! So, the orginal seller had sold me five-year old stock! I put a new one in and it's like a new car!
Had a similar problem on my Suburban a few years back. Brand new battery and I had starting problems. It even kept testing good. It was so bad, I even started carrying a spare around to jump start because I couldn't guarantee it would start after standing at work for a few hours. Finally, I stopped blaming the car and switched the battery. No problem after that.
On my 2007 XK the first battery failure symptom was at a fuel stop after 40 minutes of highway driving. The engine simply did not start - cranked but no start. After a 10 minute wait it started. Being very aware of the random symptoms of battery failure, I opted to put in a new and correct battery. When the battery was presented to me at the counter I asked the clerk if it was fully charged; he said it was. Seeing my doubting expression, he pulled up a battery condition analyser. The printout read GOOD.
Uh huh…..I took the battery home, put it on the CTEK maintainer before installing it and it took almost 36 hours until the battery was at full charge…so much for the concept of “ battery reads good” that we so often hear.
Oh … and with the new and now fully charged battery installed, there have been no electrical issues - none- with the car for the past 4.5 years (and no issues of any other kind either…hmmm….now that I think of it, until that fuel stop incident the car had never had any issues).
New batteries are almost NEVER fully charged at installation.
Thanks again
Thanks again
These are the possibilities and there aren't many:
Bad or failing battery-easy check
Bad or failing module within the Fiber optic loop-easy check with a bypass loop - no SDD required - most common failure is the BT module, satellite module, less so, Nav module.
Bad or failing touchscreen itself- not common, plug and play replacement with same.
needanswers
08-28-2023 09:12 AM
silversurfer1221
10-01-2021 02:05 AM
