Maintenance ?? Dealer says no need
Yes Jaguar does recommend fluid changes before 100k miles - Per my owners manual
Brake fluid - flush every two years regardless of mileage. Flush is due on your vehicle.
Coolant - Jaguar uses OAT coolant (Orange color aka Dexcool here in the U.S) and OAT lifecycle for automotive use is 5 years or 150,000 miles, whichever comes first, however the manual says every 4 years or 60,000 for the XK. Either way - flush is due on your vehicle.
Transmission - ZF transmissions were originally intended to be sealed for life but now ZF recommends the following ( you won't find this in your manual):
ZF automatic transmissions are filled with specially developed semi-synthetic oils.
At very high operating temperatures, the oil ages faster than under normal conditions. Examples:
Many trips at high speeds.
Many trips with a trailer in tow.
Sporty driving.
Depending on the driving style, ZF therefore recommends a transmission oil change every 80 000 to 120 000 km, or after 8 years at the latest. 80 000 km is 49,709 miles.
Sporty driving.
I have 102K on my 2007 and have not had the ZF transmission service performed because my dealer said the same thing "sealed for life". I would like to keep the vehicle for the long haul so i want to have it done by a competent experienced service provider. Has anyone here had this done?
I bought my 2008 last year with 24,000 miles, great car but no service records at all. At 30,000 I had a Jag indie change ALL fluids & filters so I would have a starting point going forward. Doing the trans fluid and filter is really no big deal, somewhat expensive, but otherwise easily done.
Given your current millage I would do it soon.
Any good transmission shop can change the fluid (and the filter/pan) on the ZF (the mechatronic sleeve should be done at the same time). I had this done in my XJ8 (x350) with no problem at all. My XK has only 57,000 kms on it but I have the new pan/filter and mechatronic sleeve ready for when I take it in.
Welcome to the forum pcg,
Envy337
04-15-2007 03:47 PM
