Maintenance History for 8 Years and 135,000 Miles
2007 XK Convertible Blue. Thought you might be interested in my maintenance history and the costs after 8 years and 135,000 miles.
History does not include routine oil changes and minor things like changing light bulbs.
9777 miles - steering wheel control for track selection replaced under warranty.
14222 miles - low speed hit in rear - bumper cover replaced. $1754.44
20300 miles - another low speed hit in rear - bumper cover, reverse sensor and reinforce bar replaced. Beginning to think blue is a jinxed color. $2761.38
20341 miles - wheel alignment, intermittent battery problem solved by tightening positive battery cable clamp, intermittent failure outside temperature gauge, problem solved by display module update and tightening. Corrected under warranty
21134 miles -discovered paddle shifters were reversed (don’t use them so took a while to discover this). Corrected under warranty.
36500 miles - lousy stock tires replaced with Continental Extreme Contact DWS tires $1068.00
45235 miles - passenger side small window motor and regulator assembly replaced under warranty. Right visor making clicking noise when raised or lowered. Visor replaced under warranty.
44986 miles -front and rear brake pads and oil change. $567.09
61248 miles - replace satellite radio module - had a short. Replace thermostat and housing - $1938.48 and included an oil change and was done at a Jaguar dealer
82713 miles - front brakes, repair clogging AC condensation pan tube - this appears to be a design defect. $923.19. This was $373.00 to repair the drain issue and the remainder for the brakes
90714 miles - replace Continental tires with a new set. Got over 50K out of the first set. $1103.48
100980 miles - repair washer fluid leak - hose had come loose - $393.69 but this also included a tuneup with plugs and a fuel filter.
116112 miles - while parked someone damaged the drivers side rear quarter panel. It was very little damage but the quarter panel needed to be replaced. This was when I learned about the expense of an all aluminum car for repairs. My normal body shop estimated what I expected about $2000. But then after about 2 days called and said because it is all aluminum it needed to be repaired by an aluminum certified shop. When all was completed my insurance company paid all but deductble. Total was $9019.61!
123305 miles - saw some drops of fluid on the garage floor. Found that the expansion tank for the radiator had a crack and it was replaced. $895.14 but this included an oil change, tuneup and drive belt replacement.
132181 miles - one tire pressure monitor sensor broke and was replaced. $140.70
133650 miles - not really a repair but had all 4 allow wheels refurbished - taken down to bare metal, all curb nicks removed, all four put back into round and all repainted at $200/wheel and they look like new. - $800.00
134343 miles - front brake rotors and pads replaced, both front wheel bearings replaced, replace transmission fluid pan - $2572.16
Last edited by user 84302; 04-22-2016 at 04:59 AM. Reason: To add to the title that it is a 2007 XK Convertible
The following 11 users liked this post by user 84302:
01Silverstone (04-23-2016),
1 of 19 (09-28-2016),
bocatrip (09-28-2016),
guy (04-25-2016),
hdavidson (04-22-2016),
and 6 others liked this post.
Thanks for sharing, though. Nothing too surprising I would say, other than the $10k in body work for "minor" damage... good thing insurance picked that one up!
Its nice to hear the X150/4.2 is capable of almost 150k without any major problems when properly taken care of. Hoping to get 250k out of my LR3. I doubt my XKR-S will ever see 150k. Only put about 4-5k a year on it.
Lothar52 (04-25-2016)
Apparently the paddle shifters were just hooked up backwards - the left one did what the right one should do and vice versa. From the invoice it appears all they did was remove the airbag and adjust the connectors. You've got to wonder how that could happen in manufacturing and then get by quality control. Maybe the configuration is reversed for England.
On 9/26/16 with 144,286 miles the alternator failed. Got a warning message that the battery was not charging. When the engine was shut off something in the engine compartment kept running loudly for about 5 seconds. And that happened consistently for the 5 times the vehicle was turned on and off before I got it to the shop. The shop reported that the bearings were still good but it was only putting out 1/2 amp. Replacement cost was $589.45 (361.45 for the alternator and 228.00 for labor)
user 84302 (09-29-2016)
He won't escape it forever, they seem to all plug eventually. Mine was fine until a couple months ago. After 9 years you would think your safe. NOT. The A/C drain however is only a one hour fix so, not so bad.
There's a slight pull back of the leather on the dash towards the driver's side close to the window. It's barely noticeable. And the A/C leak was repaired at 82713 miles by inserting a new tube. However, I note that there is no drip under the car now and every once in a while I hear sloshing. I suspect it is partially clogged but not leaking into the passenger compartment
Received 2,012 Likes
vsol
04-15-2016 07:11 AM
Nee_the_Bogeyman
04-03-2016 10:41 PM
DanielSWE
03-28-2016 06:22 AM
