Maintenance records
Interestingly, at least in the UK, Jaguar have started putting service data online for cars built from June '13 onwards. I assume this is only accessible to the owner, but at least there is a repository which should, in theory, be available to subsequent owners. I don't know what level of detail would be available, and it obviously won't show any non-dealer work that gets done, but better than nothing.
I actually wrote to the previous owner of my car (name & address shown on the registration docs.) to ask if he'd ever experienced any issues or had any out-of-the-ordinary warranty work done. He kindly replied by email and told me the car has been hassle-free, which was good to know. Of course, I'd already bought it, but it might have highlighted areas to watch closely during the remaining warranty.
Interesting that you mention brake fluid. That seems to be one of those things that nobody actually does, but it is probably a good idea to do it to keep moisture out of your brake system. I'm behind on the brake fluid changing on all three of our cars!
Received 2,266 Likes
Received 10,979 Likes
I would first start with a CarFax report as most Jaguar dealers here in the USA will report service reports to CarFax. If you have ever had your Jag serviced, I am sure that your service provider (bonafide Jaguar Dealership Service Department or other brand dealership) will attest that they do in fact report to Carfax.
Slightly off-topic but I read where many dealers (of any/all brands) never realized the service records were going to CarFax.
In the USA there are two primary vendors for dealer computer systems/operating systems/software, Reynolds and Reynolds and ADP. ADP, apparently, automatically sent dealer service records to Carfax unless the dealer actively "opted out" when contracts were signed or re-upped. It was apparently something that ADP just sorta "slipped in" and often made no mention of. They'd go into dealer systems (remotely, of course) and grab the info every week. Some of the dealers were very unhappy.
All the dealers I ever worked for were on Reynolds and Reynolds and the subject never came up and service records were never reported. I think the agreement was exclusively between ADP and Carfax.
Things may have changed in the last few years; I dunno.
The older the service records are, the most likely probability is that the data may have been eliminated from their computer systems. I have been told look back on computer data is about 3 years.
On Reynolds systems (I'm sure other systems as well) the dealer can customize how long service history for any VIN is kept. You had "summary history" and "detail history" and could set different parameters for each and tie it in with how much activity a VIN has.
After I bought my 2009 XKR in May 2013, I took it to the dealer within a month for an oil change, filter and multi check inspection.
Then about 2 weeks later I looked at the CarFax and sure enough the vehicle registration, and service for the oil change from the Jaguar dealer showed up on the Carfax report. So it appears that Doug above is correct, on the reporting and can only assume the Jag dealer must be linked up with ADP (Automatic Data Processing).
37driver
10-01-2015 03:02 PM
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
