My XKR 4.2 was overheating and after adding coolant I noticed a major coolant leak from the back of the engine... what would this be? And what does anyone have a step by step guide to fixing this? Would this be the water pump location under the manifold? Under the car And for reference in this area below
Possible Throttle Body Coolant Line got ruptured or disconnected. Take all that intake crap off the top and follow the hoses.
It could also be the coolant lines under the blower, which is MUCH more involved.
How many miles on the car? I know nothing of your car but I can tell you that all my hoses (manufacturing date September '06) were replaced at 75,000 km. Though they aren't leaking, it is time to do them again this fall. I do change the coolant every 2 years.
While the supercharger is off, it will be thoroughly cleaned, fluids replaced, etc at the same time.
Worst case scenario, your car is 18 years old... you are significantly overdue for this maintenance requirement.
I believe you are correct in being overdueoverit has just hit 250,000kms! I'm already getting a lot of suspension bushings replaced and sway bar links.. haven't touched the engine but I'm assuming there's a lot that should be done I just have no clue as i bought it a month ago..and this is the first thing that has happened 🤯 could you do a guide if you do your maintenance on your hoses unless you have a link to how to remove the supercharger etc to gain access. I'd like to work on this car myself as much as possible just don't have the knowledge and havent seen much in terms of yourube videos.
I believe you are correct in being overdueoverit has just hit 250,000kms! I'm already getting a lot of suspension bushings replaced and sway bar links.. haven't touched the engine but I'm assuming there's a lot that should be done I just have no clue as i bought it a month ago..and this is the first thing that has happened 🤯 could you do a guide if you do your maintenance on your hoses unless you have a link to how to remove the supercharger etc to gain access. I'd like to work on this car myself as much as possible just don't have the knowledge and havent seen much in terms of YouTube videos.
