Manual transmission conversion? Dreaming?
#141
Just to clarify even though this is not what this thread is about.
VPW is a format of J1850- they are not different (VPW= Variable Pulse Width). This is a format of communication GM used from 1996-approx 2004
SCP is a different format- that is J1850-PWM (pulse width modulation) and is Ford
Again, not what this thread is about.....
#142
Glad to hear that you are sorted for now ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Funny, my X150 purchase was kicked off when I saw a 4200 Skyhook advertised nearby. They would not give me a date for a test drive so I didn't take it further, also put off by the reputation of the Skyhook reliability and the cost of the usual spare parts such as brake discs. No manuals turned up anywhere near me
Today, there are only 3 for sale in Germany on Mobile.de
Shock! 5 years later, that same 4200 is still for sale. Same photos, same mileage, slightly higher price. Something very fishy there!
https://suchen.mobile.de/fahrzeuge/d...l?id=262795125
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
The 4200 can be a handful to own. A friend traded his GranSport in on a Ferrari at a Ferrari-Maserati dealer. His GranSport was the nicest condition one in the country. The third brake light went out and the Ferrari dealer ended up selling the car at auction as it would've been to expensive for them to fix! They didn't see the value in the car. They had it in the showroom for a couple weeks until reality sat in. If it weren't an FM dealer, maybe the few little things may not have been as expensive on parts.
I ruined a shirt once on a sticky vent transferring to the sleeve cuff; that was my first time in one. Car was only 3 years old and everything was melting inside.
#143
#144
Best price I found for front discs was 550€ a pair, and they are not that big or special.
My FIAT Coupe has the same black rubberised paint on the centre console. I have had to remove it with acetone and repaint it with mat black spray. Still have to do the one around the handbrake lever. Horrid stuff!
Fiat Coupe: https://www.autobelle.it/altre-immag...1519643054.jpg
mosesbotbol (01-15-2020)
#145
#148
Yes, skyhook is to be avoided like the plague. Same with the cambiocorsa IMO. The thing is this type of tech was in its infancy then. It was just not there yet. The problem is most people opted for it, exactly because it was new. So manuals are very rare and command more money normally. They are also cheaper to run as they don't eat clutch as the cambiocorsas do and the clutch is a bit cheaper too. ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
#149
![Icon Rolleyes](https://www.jaguarforums.com/forum/images/smilies/icon_rolleyes.gif)
#150
I think they were just bad. Even if you tried driving them fast and hard. It shifted slow and too much body roll. The Gransport iteration and later cars are better. But the earlier cars are not good in that regard.
#151
... but they are getting harder to repair / keep going as some parts are disappearing already. Ours is in the last throws of the bodywork restoration and it will then get a complete suspension, bearing, etc. refresh and new timing belt. Then we will have to be careful with it ![Icon Rolleyes](https://www.jaguarforums.com/forum/images/smilies/icon_rolleyes.gif)
#152
I was toying with getting a Barchetta but a lot of the plastic trims are getting brittle and there are very few about that haven't suffered rust due to leaky roof seals. An SLK or a Z4 are simply better made so would be a better bet for a cheap convertible.
Getting parts for any of these cars is getting hard as the FIAT group just doesn't have a history of supporting old cars. There aren't enough models that have a long-term following to make it worth adding to their business model.
#153
Getting parts for any of these cars is getting hard as the "standard" FIAT group just doesn't have a history of supporting old cars. There aren't enough models that have a long-term following to make it worth adding to their business model.
#154
Yes ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I used to know a person who had a 2001 GTV. It was in tip top shape and was the V6 too. Lovely sound and looked lovely. He used to say he had no problems finding parts for it. But it has been a few years. Maybe now it's different and similar to the Coupe and Barchetta. Those GTVs came out I think in 95. So about same age.
#155
Real pity.
#156
Wow, why all the negative reactions? Is it because me thinking about doing that hurts your egos, as in I think your car is no good the way it is? If so I apologize. Not my intention. I'm just a fan of actually shifting. If you take away that, driving is not as fun TO ME. But I respect people who don't like to shift a manual. To each his own. But I guess it's too much to expect respect back.
#157
I think our best shot at a manual conversion would be the ZF S6-53. It was used by car manufacturers on cars that had the ZF 6HP26/8 as the automatic transmission.
One of the applications of the ZF S6-53 was in the 2006 S-Type diesel.
The F-Type comes with the ZF S6-45 which has a lower torque rating.
I am not sure if the two pieces of information above give a clue on how to handle electronics.
#158
If you take out the ZF 6HP26 then you need a CAN device to simulate it (i.e. accept network messages to it and send back meaningful ones as if it's still there and doing the right things).
Or you remove a heap of logic from the PCM involved in the above.
I suspect hardly anyone, quite possibly no-one, is prepared to hire someone with the skills to do any of those.
Failing that, you stop using the Jaguar-supplied PCM and use a standalone one - which has a ton of knock-on issues (discussed in threads elsewhere). I think this is the more viable but very painful way.
Another choice would be to remove the Jaguar-supplied engine & autobox and drop in some others but again this has knock-on issues.
#159
The following 2 users liked this post by Cee Jay:
mosesbotbol (04-02-2020),
steve_k_xk (04-02-2020)
#160
