Manual transmission conversion? Dreaming?
Old 01-15-2020, 08:03 AM
Default J1850-VPW
Just to clarify even though this is not what this thread is about.
VPW is a format of J1850- they are not different (VPW= Variable Pulse Width). This is a format of communication GM used from 1996-approx 2004
SCP is a different format- that is J1850-PWM (pulse width modulation) and is Ford
Again, not what this thread is about.....
Originally Posted by JagV8
J1850 (aka SCP) is Ford (& Jaguar et al).
GM used VPW. Not the same as J1850.
  #142
Old 01-15-2020, 08:17 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Originally Posted by neilr
Glad to hear that you are sorted for now
Funny, my X150 purchase was kicked off when I saw a 4200 Skyhook advertised nearby. They would not give me a date for a test drive so I didn't take it further, also put off by the reputation of the Skyhook reliability and the cost of the usual spare parts such as brake discs. No manuals turned up anywhere near me Today, there are only 3 for sale in Germany on Mobile.de
Shock! 5 years later, that same 4200 is still for sale. Same photos, same mileage, slightly higher price. Something very fishy there!
https://suchen.mobile.de/fahrzeuge/d...l?id=262795125
The 4200 is an attractive car. I like that color combo; was popular choice.
The 4200 can be a handful to own. A friend traded his GranSport in on a Ferrari at a Ferrari-Maserati dealer. His GranSport was the nicest condition one in the country. The third brake light went out and the Ferrari dealer ended up selling the car at auction as it would've been to expensive for them to fix! They didn't see the value in the car. They had it in the showroom for a couple weeks until reality sat in. If it weren't an FM dealer, maybe the few little things may not have been as expensive on parts.
I ruined a shirt once on a sticky vent transferring to the sleeve cuff; that was my first time in one. Car was only 3 years old and everything was melting inside.
  #143
Old 01-15-2020, 08:22 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Sorry, I missed the PWM part after J1850 when I put SCP.
I like the pic (though it's a bit definitive about VPW and pin 10 - the pin might be present though VPW signalling wouldn't be using it).
  #144
Old 01-15-2020, 08:42 AM
neilr's Avatar
The original colour is a dark blue and was wrapped at some point. Blue with red interior is a bit odd but sort-of works. Cream or tan would have been better.
Best price I found for front discs was 550€ a pair, and they are not that big or special.
My FIAT Coupe has the same black rubberised paint on the centre console. I have had to remove it with acetone and repaint it with mat black spray. Still have to do the one around the handbrake lever. Horrid stuff!
Fiat Coupe: https://www.autobelle.it/altre-immag...1519643054.jpg
mosesbotbol (01-15-2020)
  #145
Old 01-15-2020, 09:06 AM
MikeV8's Avatar
Yes, skyhook is to be avoided like the plague. Same with the cambiocorsa IMO. The thing is this type of tech was in its infancy then. It was just not there yet. The problem is most people opted for it, exactly because it was new. So manuals are very rare and command more money normally. They are also cheaper to run as they don't eat clutch as the cambiocorsas do and the clutch is a bit cheaper too.
  #146
Old 01-15-2020, 09:07 AM
MikeV8's Avatar
My FIAT Coupe...
Always found them charismatic. The 5 cylinders turbo sound lovely too.
  #147
Old 01-15-2020, 09:27 AM
Been a fan of the Fiat Coupe since it came out. Was never imported to the US.
  #148
Old 01-15-2020, 09:32 AM
Many owners did not know how to drive Cambiocorsa cars correct. They need to be driven fast and like a manual; not so many owned them like that. Same with Vantage Sportshift, but more owners drove it as expected.
  #149
Old 01-15-2020, 10:10 AM
neilr's Avatar
... but they are getting harder to repair / keep going as some parts are disappearing already. Ours is in the last throws of the bodywork restoration and it will then get a complete suspension, bearing, etc. refresh and new timing belt. Then we will have to be careful with it
  #150
Old 01-15-2020, 11:59 AM
MikeV8's Avatar
I think they were just bad. Even if you tried driving them fast and hard. It shifted slow and too much body roll. The Gransport iteration and later cars are better. But the earlier cars are not good in that regard.
  #151
Old 01-15-2020, 12:01 PM
MikeV8's Avatar
I can imagine. I guess it's probably the same story with the other similar cars from that era like the Barchetta, GTV and Spider?
  #152
Old 01-16-2020, 02:56 AM
neilr's Avatar
Yes
I was toying with getting a Barchetta but a lot of the plastic trims are getting brittle and there are very few about that haven't suffered rust due to leaky roof seals. An SLK or a Z4 are simply better made so would be a better bet for a cheap convertible.
Getting parts for any of these cars is getting hard as the FIAT group just doesn't have a history of supporting old cars. There aren't enough models that have a long-term following to make it worth adding to their business model.
  #153
Old 01-16-2020, 02:57 AM
neilr's Avatar
Yes
Getting parts for any of these cars is getting hard as the "standard" FIAT group just doesn't have a history of supporting old cars. There aren't enough models that have a long-term following to make it worth adding to their business model.
  #154
Old 01-16-2020, 07:03 AM
MikeV8's Avatar
Yes
Real pity.
I used to know a person who had a 2001 GTV. It was in tip top shape and was the V6 too. Lovely sound and looked lovely. He used to say he had no problems finding parts for it. But it has been a few years. Maybe now it's different and similar to the Coupe and Barchetta. Those GTVs came out I think in 95. So about same age.
  #155
Old 01-16-2020, 07:34 AM
neilr's Avatar
Real pity.
Yep, both released in '93 I think, both based on forms of the Tipo 2 platform. More money went into the Alfa's suspension, especially at the rear. Parts were easy to find in the early days as they were fairly mainstream cars but body parts especially are now rare and some mechanical parts are disappearing. The GTV is a nice looking thing. I ended up going for the FIAT because it was going to be my only car and its packaging is a bit better. Both are a bit "exotic" in the land of Mercs, Audis and BMWs. Hmm! What are GTVs going for ...
  #156
Old 01-16-2020, 07:48 PM
Johnny Mayday's Avatar
JagForums Town Crier
Wow, why all the negative reactions? Is it because me thinking about doing that hurts your egos, as in I think your car is no good the way it is? If so I apologize. Not my intention. I'm just a fan of actually shifting. If you take away that, driving is not as fun TO ME. But I respect people who don't like to shift a manual. To each his own. But I guess it's too much to expect respect back.
Personally, I'm with you. Even if it's impractical, I've though about manual conversions for auto cars a lot. Ultimately, I got to like having an auto in my old XJ, but I was always intrigued by the fact that it was offered with a stick in the UK.
  #157
Old 04-02-2020, 02:46 AM
Saudi Jaguar's Avatar
I think our best shot at a manual conversion would be the ZF S6-53. It was used by car manufacturers on cars that had the ZF 6HP26/8 as the automatic transmission.
One of the applications of the ZF S6-53 was in the 2006 S-Type diesel.
The F-Type comes with the ZF S6-45 which has a lower torque rating.
I am not sure if the two pieces of information above give a clue on how to handle electronics.
  #158
Old 04-02-2020, 11:33 AM
JagV8's Avatar
If you take out the ZF 6HP26 then you need a CAN device to simulate it (i.e. accept network messages to it and send back meaningful ones as if it's still there and doing the right things).
Or you remove a heap of logic from the PCM involved in the above.
I suspect hardly anyone, quite possibly no-one, is prepared to hire someone with the skills to do any of those.
Failing that, you stop using the Jaguar-supplied PCM and use a standalone one - which has a ton of knock-on issues (discussed in threads elsewhere). I think this is the more viable but very painful way.
Another choice would be to remove the Jaguar-supplied engine & autobox and drop in some others but again this has knock-on issues.
  #159
Old 04-02-2020, 01:04 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
While some things CAN be done doesn't mean it SHOULD be done.
Get a Vantage instead.
The following 2 users liked this post by Cee Jay:
mosesbotbol (04-02-2020), steve_k_xk (04-02-2020)
  #160
Old 04-02-2020, 04:03 PM
JagV8's Avatar
Yep. May be cheaper overall.
Quick Reply: Manual transmission conversion? Dreaming?
