Manual transmission conversion? Dreaming?
#161
JagRag (04-03-2020)
#164
Here in Saudi we got two regulations implemented in the past few years.
1. You cannot import anything older than 5 years.
2. You cannot import anything that shows high fuel consumption in our data base.
I actually got my XKR from the UAE before the second law.
That takes away all of the good stuff and leaves only two cars of interest that I can bring, the F-Type and the Boxter Spyder. I am thinking anything up to 15K $ for the manual conversion would still be worth it.
#165
#166
Cannot import a Vantage. I think all V8 sports cars would not meet fuel consumption limits.
By the way, all of what I mentioned is for personal imports. Dealers can still get whatever cars wanted, so I can get a new Vantage if I can afford one.
#167
#170
I think our best shot at a manual conversion would be the ZF S6-53. It was used by car manufacturers on cars that had the ZF 6HP26/8 as the automatic transmission.
One of the applications of the ZF S6-53 was in the 2006 S-Type diesel.
The F-Type comes with the ZF S6-45 which has a lower torque rating.
I am not sure if the two pieces of information above give a clue on how to handle electronics.
Something to think about: Use the ZF S6-53 from the 2006 S-Type diesel complete with shifter and linkage. Modify the clutch/brake pedal box from an appropriate donor. Retain the ZF automatic computer and emulate the necessary inputs.
#171
Your last sentence is the issue. The mechanical installation can be done but it's the SW that no one has broken the code with.
Cee Jay (04-24-2020)
#173
The problem with such emulation is that the engine will operate where it thinks the transmission is doing what it is told, so very erratic things will happen.
#174
Unlike yesteryear the transmission provides various signals both input and output from the ECM. So I would think in order to fool the ECM you would need to find out what the various signal voltages and sensor information to feed into the ECM. You would need this information from Jaguar which I bet would be reluctant to do. I would also believe you have to modify the ECM which would be another issue. One way to do this is to get someone to make a stand alone ECM that just runs the engine and it's controls. Let the transmission be mechanical with no electronic features in it. I'm sure anyone of this issues can be solved , all you would need is time and money. I'm not against it and would like to see it done but I don't know if someone would want to invest in it. It also may be easier to install a DCT in place of a 6/7 or 8 speed.
#176
Yeah, good luck. Read up on how the car works and then you'll scrap this idea.
Cee Jay (04-26-2020)
#177
As stated, the transmission is highly integrated into the ECM of our cars. That being written again, The transmissions are "Smart" and do all of the shifitng work. The communication between the Trans controler and the ECM are mainly CAN messages. (There is park,reverse, and brake signals involved too.)
Last time I looked into this, the simplest way I could figure out is to satisfy the "park signal" so that the engine will rev and operate independent of the transmission. One thing I didn't figure out is weather the engine will run in a "closed loop" mode and/or the car being in park, will affect VVT.
The only other apprioach is to use an aftermarket ECM, but for those in smog states, this will be an issue unless the ECM outputs all the DTC codes, Vehicle VIN, codes and other data that is read from the car when it is inspected.
#178
Having read this entire thread before posting, negative responses were anticipated. Let us begin again:
Stipulations:
1. The ZF 6HP26 automatic with paddle shifters is an excellent solution.
2. Economically, all costs associated with a conversion should be considered sunk.
3. Jaguar, we are told, will not support conversion efforts with access to CAN, etc.
4. Federal (USA) regulations prohibit modifications to the the Engine Control software.
5. The ECM and the TCM function together. TCM affects engine and vehicle performance.
6. Differential ratio for the ZF automatic may be higher than optimum for a manual transmission.
7. A bolt-on transmission for the Jaguar 5.0L may be less than the torque rating as the ZF 6HP26.
8. Drive-shaft length, universal joints, etc will likely require a custom shaft.
9. Drag racing or or 0-60 MPH performance may not be improved and may actually suffer.
10. Re-sale value of the vehicle may be less than before MT conversion.
So, why do a manual conversion? A: Because ... (a whole other discussion.)
Assuming that the mechanical conversion is accomplished and accepting the differential ratio (another discussion), the electronics is understood to be the stumbiling block.
Since, Jaguar is not cooperative and Federal rules discourage mods to the ECM, retain the TCM and emulate the descrete inputs.
Information about the transmission functions is available from sources other than Jaguar. possibly from ZF or the other vechile manufacturers using the same or similar automatic transmissions.
This post is a request for constructive discussion. Bah humbug! has been heard loud and clear.
Lets hear from those who know if the Ford Mustang V6 transmission will bolt up. Or what pedal box is a likely candidate.
Maybe a discussion about the ZF TCM inputs/outputs?
We can do this!
Best regards,
Bill
Stipulations:
We can do this!
Best regards,
Bill
MarkyUK (06-10-2020)
#179
Just pay one of the (few) firms that offer this kind of thing. Big $$$ but you get it in less than a year.
If you don't fancy that, either
1.watch & decode the CAN messages so you can fake them
or
2. mimic the internals of the ZF trans so you can fool a TCM which hasn't actually got those internals (this will be hard because you'll have to ramp signals up & down to mimic things like fluid pressure changes)
or
#180
There are programmable microcontrollers that can be used to accomplish the emulation(s).
It may be useful to mount switches on the shift linkage. Even maual transmissions monitor reverse for backup lights.
This is doable. The talent needed is here on this forum. We just need to work together.
Best regards,
Bill
