Hello.
I have a recurrently failure (check engine light) that is generated by the TMAP or Pressure sensor, that senses the incoming air pressure to the engine.
I bought a new sensor and before installing it, I would like to check if someone has done it before, without the help of a Jaguar service.
The item I bought says it should be installed by trained staff.
Is there something I should consider before installing it?
Thank you.
Please note, I highly doubt your MAP sensor failed (rare), it is more likely that
you have a leak in your air intake system which is causing your MAP sensor to display
a error code.
