May eat my words
I got an inspection scope for christmas so I could see a few areas in the home and cars. So with all of the discussions on the water pump I did a little fishing this morning. Although I haven't seen any tell tale signs of the water pump leaking (like low water in the tank) I had been concerned about all of the talk on this form. I am at 14,985 miles on my 2012 XKR. I snaked the scope down and this is a picture of the scope. I can not make out if this is antifreeze but it can't be anything else. It was a little cold to pull down the plastic skid plate so I'll have to do that later this week. If it is the problem I'll call the dealer next week and see what's covered. It will be interesting to see what the 4/50,00 and the CPO plan cover. The picture is a little blurry but you can get it.
I'll pull the plastic belly pan some time this week and take a closer look. Then wipe it down and take it for a few runs. I should be able to see where the fluid is coming from just looking up from the bottom. I've put on 8,000 miles since I bought it almost 2 years ago. I also want to find out when my Platinum Service runs out and pick up a 15,000 service. I'll just have to see what happens.
Stuart I don't plan on doing this even though I could. I've decided to let this one be serviced by a dealer but I'm curious to see what the issue is. Pulling the plastic belly pans are not a big deal as I have a lift that I park/store the car on . Also it will give me an indication on how small/big the problem is. My dealer is 75 miles away so I'll most likely drive it there but only if they have a new pump in stock provided that is the problem. I can also get the 15K service done at the same time but I won't leave the car if they don't have the part and need to order it. We'll see as this isn't my 1st rodeo but my 45th year working on my cars. Only this time I don't need to go to work.
![Icon Oldskewl](https://www.jaguarforums.com/forum/images/smilies/icon_oldskewl.gif)
jagtoes,
I understand from where you are coming, as did all the easy work (oil changes, carb rebuild, water pumps, tune-ups, etc.) on my '60 Vette during the 42 years that I owned it. I did not, however, have the advantage of a lift and became intimately familiar with drive-on ramps and a creeper. I must admit that it was fun at the time, but with age comes wisdom and a desire for no more skinned knuckles.
When you speak with your dealer, be sure to get the part number for that pump. There have been at least 3 versions for the 5.0L engine, and I think the most current part number is C2Z31146. See this thread, and posts ##22 - 27: https://www.jaguarforums.com/forum/x...-154578/page2/
Stuart
Stuart
jagtoes (01-03-2016)
jagtoes,
I understand from where you are coming, as did all the easy work (oil changes, carb rebuild, water pumps, tune-ups, etc.) on my '60 Vette during the 42 years that I owned it. I did not, however, have the advantage of a lift and became intimately familiar with drive-on ramps and a creeper. I must admit that it was fun at the time, but with age comes wisdom and a desire for no more skinned knuckles. ...
Stuart
Stuart
I still tinker after all I have my wife's 89 Volvo with 355K on it and I still maintain it. In fact I'm about ready to pull the 2 piece drive shaft and replace the center bearing and the U-joints. I invested in a 4 post lift 16 years ago and it makes a lot of work easier.
FS[SouthWest]: 1987 Jaguar XJS 49000 miles 3rd owner
Lance 99
02-21-2016 08:49 AM
john_cook12
01-03-2016 09:42 AM
