Messing around with MAP sensor?
Has anyone messed around with MAP/MAF sensor interceptors / calibrators on the X150?
Pretty simple trick that tuners have used on forced induction cars by tricking the ECU into thinking you're running at high altitude and adjusting air/fuel to compensate.
On a turbocharged car it typically results in about a 2-3psi bump in boost, so I'm wondering what would happen on supercharged X150.
Example
https://splitsec.com/product/psc1-00...nal-calibrator
Would it work? Or is the AJ133/Denso just too complex for this?
Thoughts?
Example
Thoughts?
Last edited by StiggyMac; 10-16-2020 at 10:22 AM. Reason: Including MAF in discussion since we have both
You could always be higher...lol
I mean the difference between like Park City, UT and Pikes Peak, CO is still like 7,000 ft. I'd imagine that would still yield a pressure differential to make some impact.;
I do not think you're going to have any good results but keep us posted..
Why why not get an actual proper reflash instead?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
OK I just looked at the product and no it won’t do what you think it will do because it’s not meant to do that. It’s purpose is to allow you to tune an engine where you have increased the blower and you need to adjust the map sensor because it’s no longer sized correctly. You run out of headroom. So instead of having a brand new specialized map sensor custom built for your custom set up you adjust the output of your existing map sensor so that you can get the correct engine parameters needed for the bigger blower
Cee Jay (10-16-2020)
It is my understanding that the MAP sensor is re-calibrated when you fit a larger crank pulley. No need to with the smaller supercharger pulley as it cant create enough extra boost to affect anything.but the crank pulley extra diameter will result in limp mode unless the MAP is adjusted
All map sensor does is reads actual boost pressure,,, If it's past its scale then it can be easily readjusted in ECU But going past it requires a significant increase of boost ..
__________________
Plus, I can piggy back the MAP adjustment on a reflash for "test" purposes. lol
