Mickey mouse upper control arm boot replacement
As most of us have experienced, my front upper control arm boots have perished last year. I can see there is still a fair amount of grease around the joint as well as some road grit getting inside.There is no play or noise whatsoever. I was wondering, since it is so accessible, isn't there a simpler way to wrap some kind of thin rubber sheet around the upper joint while securing it with 2 thin plastic ties as a very temporary means to keep more debris from getting inside? I've read about the boots that are available for replacement, and I know this is not the way to go for a permanent fix, but as I do so little driving, (presently 16,000 miles ) and these joints are fairly robust....Is this feasible for the short term when I don't drive in the rain, and I do less that 1,000 miles per year? Any thoughts? Thanks all. PS How about one of those Split Boots?
Where do I find the appropriate size split boot for our upper control arm ball joint?
I've not bought any lately (ten years? More???), but yeah, I sprayed the points with carb cleaner lightly to get the outside dirty gook off without spraying away all the existing clean grease. I'd wipe them a bit the fit the big end and inject grease through a tube into the small end before clamping.
They sell them by end size and length. They cover a range, so it's not super critical.
bocatrip (Yesterday)
exiledbrit
04-16-2021 11:52 AM
nhdoc
66
05-13-2018 04:10 PM
gabrielduenas
03-06-2015 12:25 PM
Currently Active Users Viewing This Thread: 9 (4 members and 5 guests)
