Mina Gallery Grille HELP
I used 8 of the provided screws, starting at the far left and the far right and moving inside. I advise that you pre-drill the holes into the factory plastic mesh. Make sure that the holes are at the crossings of the mesh for maximum hold.
My greatest problem was to find a small enough phillips screw driver to drive the small screws. Make sure you have one that fits the small heads tight as you do not want to round off the phillips heads. The heads are just large enough where it will not go through the mesh and, at the same time, small enough where you can not see them from any distance following the installation.
Good luck,
Albert
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
xjrjag
09-27-2015 01:53 AM
WTB[SouthWest]: Mina Gallery X350 exhaust
XJ8JR
09-11-2015 12:31 AM
albert, big, gallery, grill, grille, install, installation, installing, instructions, jaguar, lexus, mina, xk, xkr
