Mina Upper Grilles for 2007?
I'm getting the OEM wire upper and lower grills for my 2008 portfolio, they should be arriving sometime this week.
They're a lot more open than the Minas and replace the original grill not go over it. (The look is a lot more like the pre-2007 XKR grill).
I'll post photos here when its done.
It might not exactly be this week as I'm thinking about getting the grills nickel-plated before they get fitted, so they're super bright like the 2010+ plastic grills are.
Stock Grille Before: (sorry its blurry didn't check the photo until after I had the grille changed but you all know what a stock grille looks like).
![](https://www.jaguarforums.com/forum/members/justniz-28922-albums-garage-xkr-4330-picture-original-grille-12507.jpg)
OEM Wire grille After:
![](https://www.jaguarforums.com/forum/members/justniz-28922-albums-garage-xkr-4330-picture-new-grille-12506.jpg)
The difference is amazing. The 2008 stock grille is horribly plasticky and you don't really notice how much it brings the whole car down until its gone. The 2010+ stock grilles don't look quite as bad but they are still plastic. A real wire grille looks nicer again by a long way and just more classy and authentic. Until 2007, R versions of all Jag models always had actual wire grilles. As a long time Jag fan, even the nicer 2010+ plastic grille looks too cheap and just plain 'wrong' in my opinion. By putting a wire grille on (especially as its an OEM part) I feel I'm just correcting the job that Jag themselves failed to do right this time round.
While passing the Bentley dealership, I noticed their 2012+ Continentals apparently have mesh grilles made of exactly the same nasty plastic mesh as the 2010+ XKRs. I'd be REALLY pissed if I'd paid $200k+ for a car and got that.
For others thinking about this: Wire Main grille jag part number: C2P17354 Lower Grille: C2P9190
Cost $251 + $189 through my local jag dealer but I found too late you can get them significantly cheaper on the interweb.
I also had just the badge mount chromed to match the grille wire as it comes with a dull finish. (cost $25 at my local chromer). The badge+mount are easily removeable (just 2 bolts) incase you prefer the plain grille look.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
