Minimal voltage level for the car to run well ?
guy (01-28-2024)
Hi,
So I just went to check the car.
Opened the trunk (so yes, the trunk lights were on, but didn't open the car so all was still closed)
I checked the voltage with the charger ( which was at stage 7)still plugged and it showed 13,46V on the battery terminals.
I unplugged the Ctek and waiting 1mn and it showed 12,86V.
Does it sound right to you ?
Should I perform anything else ti check the battery ?
thanks.
thanks.
Richard
As said above you can’t get a usable battery voltage reading with the battery connected to the car. With the battery disconnected and fully charged I agree it should be closer to 13V as this’s been my experience as well. With the battery fitted and the generator off, you’ll see all sorts of voltages at 12V and higher which don’t necessarily mean the battery’s bad which why testers load test a battery to determine its true voltage and capacity. A simple DIY test with a VOM connected directly to the terminals then try starting the car. If the voltage stays above 10V it’s good, if it drops below 10V something’s off.
If the new battery starts fully charged and the vehicle sits for a week or more locked and you find the battery below 12V, then either the battery’s bad or there’s definitely something in the car’s electrics not shutting down.
RichardS (01-29-2024)
Received 1,103 Likes
FYI @Tiepolo For an AGM battery:
https://www.batteryskills.com/agm-ba...voltage-chart/
Lead-acid have a maximum charge of 12.6v.
As we have all pointed out, a battery at 12.4v is only at 50% capacity. And that is not the good.
Hi,
thanks.
thanks.
A battery with surface charge has a slightly elevated voltage and gives a false voltage-based SoC reading. To normalize the condition, switch on electrical loads to remove about 1 percent of the battery’s capacity or allow the battery to rest for a few hours. Turning on the headlights for a few minutes will do this.
So if yer trunk lights were on this would basically kill the surface charge - so 12.86 would be good. You could wait 5-10 mins with the trunk open and see what it is then.
#28
