Moisture in Headlights '13 XKR
MaximA (03-13-2014)
I drive with my headlights always on. I consider it a simple safety issue in that it is nice to be seen, and daylight running lights are not bright enough for me.
Whatever your feelings on this, running the headlights does produce a certain amount of heat; and I have never, ever had any condensation problems not only with my '07 XK but also any other car I've owned.
This was a major issue on the previous XK8/XKR model which was never resolved throughout the entire ten year production run.
I was delighted to find my XK never gets any moisture in the headlights and we have plenty of rain and damp to test it thoroughly in this country!
Translation: "This happens all the time and we can not fix it. If we were to fix it and replace this would be happening every 3-4 months. Jaguar does not have the resources to take such a hit... you understand. You are going to have to live with it! Good Luck making your headlights look good in 20 years from all the streaking. When it gets bad enough, buy another jag!".
Translation: "This happens all the time and we can not fix it. If we were to fix it and replace this would be happening every 3-4 months. Jaguar does not have to resources to take such a hit you understand. You are going to have to live with it! Good Luck making your headlights look good in 20 years from all the streaking. When it gets bad enough, buy another jag!".
The following 2 users liked this post by MaximA:
Lothar52 (03-13-2014),
resident_fng (02-23-2024)
This is all I received, and I asked for more detail as this is BS. It looks like I have un wiped windex in my headlight.
According to Jaguar, moisture inside the headlight will occur but it does not affect the operation of the lights working. You could reference your user manual and it will state that this is something that happens but does not interrupt with the internal mechanism of the headlight.. Unfortunately I cannot order a headlight because of moisture in it.
I think the reference referred to is on page 31 of my 2013my XK Owners Handbook.
"Headlamps - Condensation"
"In certain circumstances, misting may occur on the inside of a lamp lens. This is caused by natural changes in environment conditions. This misting is not detrimental to lamp performance and will clear during normal usage"
It does clear...but it leaves a damn dirty water mark that you cant clean... sucks!
MaximA (03-13-2014)
