Monsoon in India
pedoc (07-05-2023)
Knowing how important it is to keep them clean, could you please guide me to precisely where to look for these?
thanks in advance.
John
hi !
I don't know how to describe the shape of the wipers, but the wiper blades were cut , replaced last month.
TYRE TREAD DEPTHS
TYRE TREAD DEPTHS
FRONT PASSENGER TYRE - PIRELLI (255, 35, 20) Y 97
DEPTHS (5.5, 5.5 , 5.5)
FRONT DRIVER SIDE TYRE - PIRELLI(255,35,20) Y 97
DEPTHS (5.5, 5.5, 5.5)
REAR PASSENGER SIDE TYRE MICHELIN (295, 30, 20) Y101
DEPTHS (6.0 , 6.0 , 6.0)
REAR DRIVER SIDE TYRE MICHELIN (295, 30, 20) Y101
DEPTHS (6.0, 6.0, 6.0)
thanks !
thanks !
Pedoc
Wipers sound good to go..
As for the tires, I don't know if you meant mm or 32nd's for the tread depth numbers. I'll assume 32nd's
The tires when new are 10/32 so at 5 to 6, they are roughly half way through their tread life.
In any case, I second the previous advice to slow down for standing water as not to hydroplane, or even evaluate if it's safe to go through at all.
I also suggest to check the rubber door and liftback seals to see if they are cracked or torn as they may let water in...
Mizzleman
Mizzleman
ITS IN MM.
It was given in this form by the jaguar service centre 1 month back .
Just confirmed from them .
Thanks to you , today I studied the various ways in which tyre tread is expressed.
Sound advice from you regarding hydroplaning.
Will not take the risk.
Double checked the seals , they are ok as of now .
Dr Ali
Dr Ali
