MoscowLeaper-programming question
MoscowLeaper,
Since you have intimate knowledge concerning the 2007/2008 xk engine and transmission controls I assume (hope) you can answer several questions related specifically to the NA 2007/2008 xk150, 4.2.
When the selector is put in S is there a change to the CATS controls? And if so could that change be programmed into a 2008 xk as the default setting?
Is there much HP to be gained by reprogramming the NA XK without any other changes?
Thanks for your time
wj
wj
Panthro (02-02-2022)
Steve,
I would be thrilled with that performance! You should be proud.
I'm not going to spend $ trying to make my xk into a wanna be xkr. I will optimize it as much as I can to fulfill my driving style until I can replace it with an XKR. No money at the moment to pursue this desire. I need to finish quite a few things on my 2005 XK8 and then decide whether to keep it or possibly sell both to fund an XKR. In the back of my mind I'm considering selling the xk8, purchase another older, low mileage XK8 coupe and install an LS engine with a twin screw. Sell the 2008XK replacing with a lower mileage 2013-14 XKR convertible.
We'll see, I'm getting old might not happen.
Have you gone to the strip with the 4.4 installed?
wj
wj
